Transmission Replacement Parts Source Needed
G
My 1959 BT7 is having the transmission overhauled, and I recently learned that the mechanic is having some difficulty finding some replacement parts. I am not sure exactly what he needs at the moment, but he does have Moss and Victoria British catalogs.
What other sources are there for difficult to find parts?
Are there any ways to upgrade my transmission and make it better than the original, while we have it apart?
Many thanks
Will Harrison
G
The mechanic that is helpig me with this has found a rebuilt layshaft that is priced at $356
including our exchange. Can I beat this price elsewhere or not?
Will
RF Thom
John Esposito @ Quantum Mechanics Ltd. is a great source & extremely knowledable. He is at [203] 459-9612, 505 Wheller Rd., Monroe CT 06468 or e/mail - quantumechan@earthlink.net.
I do my own rebuilding but found John has those had to find parts not listed in Moss/Vic British. By the way Moss has the wrong split bushing for the end of the gear shift lever. I tried to alert them to this but they're brain dead.
Regards, Bob
G
Many thanks for your input from me and my mechanic. I wish I could do the work myself,
but I am not confident enough to tackle a tranny.
Will
bighly
I also recieved a wrong split bushing for the end of the shift lever from Moss. I went round and round with them and they said "well no one else has said this is the wrong bushing. This means we have 2500 wrong parts in stock." I ordered another from them and it was correct the second time. The wrong one was too small in diameter on the inside and I goofed it up pretty bad (messed up the retainer). I just cut my losses and run once it's sorted out. Some of the Moss phone people are really bone headed.
RF Thom
To Blighty - You found the same problem - internal ball dia. too small [wall thickness to great]. Victoria British have the right bushing. I was ordering some other parts from them and decided to try their bushing. Not only was it the right size but it was brass material in lieu of the more available nylon.
Regards, Bob
nichola TR6 Transmission front seal replacement question Triumph 8
Zitch TR4/4A Non OD rear transmission seal replacement Triumph 1
TimK Transmission Removal/Replacement Austin Healey 3
JohnnyMead Transmission Mount Replacement Triumph 3
miranda Transmission fluid replacement Austin Healey 18
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
AUSMHLY Denis Welch Pre-Load Transmission Washers Austin Healey 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
S MGB Transmission cross member re-install MG 14
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
WHT BJ8 Transmission Installation Austin Healey 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
T How to ship transmission from Canada to Rivergate in Tennesee? Spridgets 8
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
A TR6 Installing differential and transmission Triumph 10
