transmission inspection
v8mgbal
hello all, how can you check a tranny to tell if its ok if its not in a car thanks.also its a 1275 ribcase 1972 midget
jlaird
Can mostly be done but takes experience.
Take the side cover off and see if it is not chiped or worn mostly is about all.
Careful with the detents and springs.
zimmy
shift it while the covers off
to see if it moves freely...
also turn one side of the shaft
while holding the other end
while in/out of gear
to see if anything locks/slips etc.....z
Billm
Unfortunately the most common problem with the Spridget transmissions is the whining in first/reverse and when you take the side-cover off you can't see the teeth on the first-gear slider and thus you can't tell if it will whine. Even if it is noisy it will continue to run for a long time before giving you trouble.
As Zimmy says if it shifts freely, etc then go for it.
Bill
bugimike
If it's out as you say, don't forget to "jiggle" the input and output shafts to check for play and check how smoothly they turn/spin through each gear! :wink:
If there are problems with individual gears you may be able to "feel them click" or jam up as you turn the tranny. Then look into the side-cover for a visual inspection.
jlaird
Far as I know first and reverse are square cut gears and whine.
jlaird
hehe, so will smooth case.
not a datsun smooth case! :smile:
jlaird
Well shucks.
10musketeer
I think your right Jack, they are square cut and should whine-- I hope one wouldn't be too worried about buying a Spridget with a first gear whine. Race cars that utilize square-cut gears whine like crazy! Enough to make you go crazy!
bugimike
Just gotta learn to enjoy a little cheese with your whine!!! :devilgrin: :jester:
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
AUSMHLY Denis Welch Pre-Load Transmission Washers Austin Healey 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
S MGB Transmission cross member re-install MG 14
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
WHT BJ8 Transmission Installation Austin Healey 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
T How to ship transmission from Canada to Rivergate in Tennesee? Spridgets 8
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
A TR6 Installing differential and transmission Triumph 10
PAUL161 T-Series 5 Speed Transmission MG 85
PAUL161 T-Series Replacing Transmission MG 3
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
R TR2/3/3A Transmission Service TR-2 Triumph 58
Spock TR6 Transmission Plug Triumph 4
