TR6 TR6 Exhaust
TR6Stu
Has anyone purchased a stainless steel exhaust from BritishVictoria?
The one shown in catalogue is a single pipe, my car being a 1974 is double pipe, the gentleman at BritishVictoria didn't seem to recognize what my concern was.
Any advice on removal of the existing exhaust, tips etc.?
Thanks in advance.
G
Stu,
If you know exactly what you want from Victoria British and know for a fact that what they have is what you want, then buy from them. Their return policy is excellant, no questions asked. However, if you want advice of any kind, even an explanation of what it is they are selling, you will be wasting your time asking for help. As explained to me by one of their people, Kansas law does not allow them to offer any advice whatsoever because, as she told me, they then become liable. I am not making this up and I have no bone to pick with VB. But, if you want tech help or even advice from a vendor, you may have to look elsewhere. I still do business with them but I know exactly what I want when I call them. If you need advice, check Moss or TRF. Again, I have nothing against VB, and maybe their policy has changed, but try them and see what they say when you have a question about on of their products. I would hope that they have changed but I am not sure that they have. If I seem to be softsoaping this reply it is because I just want someone to prove me wrong.
Bill
G
BPNW is also an excellant supplier with lots of good advice.
Bill
DougF
I am not familiar with the exhaust you are looking at. You need two pipes coming off of the exhaust mainfold to match your existing unit. It can go into a collector from there and do whatever the manufacturer designed it to do.
If it is a stock exhaust configuration, it will not work.
DougF
Advice on removal. A long handled 3/8 or 1/2 drive that will easily snap off your u-clamp nuts. Mapp gas or acetylene to heat up the joints real well. A large hammer and possible cold chisel. Die grinder or angle grinder with cut off wheel if you have one(works better than cold chisel).Get the car as high as you can on floor stands. Patience. Timely breaks. A good beverage of your choosing.
Be prepared to replace the studs at the exhaust manifold.
swift6
Are you referring to the Falcon system on page 29 of the current summer catalog?
The photo in the catalog shows the single pipe system that was standard for '69-'71. They also list the correct exhaust systems for '72-'74 up to CF12916, then another system for '74 from CF12917 to '76. Remember to order the correct gaskets and any fitting hardware as its not included the kit.
T
TR6Stu
I completed the exhaust installation a week ago.
Everything went well, the correct exhaust arrived, I'd soaked the manifold studs in WD40 for a whole week, it was time to start.
I could not believe how easy it was, the studs fell off, non snapped off, all the support bracketry loosen easily.
After this, I pulled the muffler box as far to the back of the car as possible, then cut it off completely. Got back under the car, the whole exhaust was just lying there, waiting to be pulled forwards.
Hope this helps.
Thanks again.
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
P TR6 76 TR6 Exhaust Triumph 6
Scotsman TR4/4A Can the TR6 exhaust go on a TR4A Triumph 5
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
B TR6 Anyone know where to get a decent Exhaust Manifold for 72 TR6 [dual] Triumph 2
B TR6 TR6 decision on header/manifold/exhaust Triumph 4
D TR6 76 TR6 Exhaust Installation Triumph 3
S TR6 71 tr6 exhaust manifold options Triumph 7
T TR6 TR6 Monza exhaust - all that and a bag of chips? Triumph 41
TR6oldtimer TR6 73 TR6 Exhaust mounting question Triumph 4
jerrybny TR6 TR6 Exhaust Manifold Triumph 5
I TR6 tr6 exhaust Triumph 17
E TR6 TR6 "Tuned" Exhaust Header Triumph 8
F GT6 TR6 dual exhaust manifold on GT6 engine? Triumph 2
N TR6 74 TR6 Exhaust bracket for OD. Triumph 2
hondo402000 TR6 Monza exhaust modified for TR6 Triumph 0
roofman TR6 TR6 Exhaust system ideas NOW WITH A PICTURE !!!!! Triumph 39
A TR6 Bell Stainless Exhaust System,tr6 ?? Triumph 7
ScottTR6 TR6 TR6 exhaust Triumph 4
Aeroken TR6 TR6 Exhaust System Mounts Triumph 2
mabbott TR6 TR6 exhaust paint....recommendation Triumph 4
71tr TR6 exhaust manifold TR6 Triumph 1
7 TR6 Hi From Tx/Direction needed on TR6 Points/Exhaust Triumph 3
V TR6 Has anyone made a custom TR6 exhaust? Triumph 11
T TR6 72 tr6 exhaust system Triumph 18
G TR6 Interest in TR6/250 Ansa exhaust Triumph 3
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
