TR6 TR6 Exhaust Manifold
jerrybny
I am replacing my exhaust manifold gasket and am wondering if there is a certain order that the bolts/nuts should be tighten down. I believe the proper torque value is 20 to 25 ft lbs but the book doesn't say which order. Also is seems that 3 or 4 of the intake manifold bolts also hold the exhaust manifold down. I'm sure many have gone thru this and appreciate any input given. Keep on 6ing. :yesnod:
G
Jerry, I just tighten everything in a random sequence, a little at a time. I don't use a torque wrench here on my header because I cannot get one to fit in the tight spots. But I feel that I use more than those numbers. I have used, and disposed of, those "header" gaskets, the thick paper ones. They burn out. Went with a Payen gasket from my set. Always use new nuts and locks. Have sprayed the gasket in the past with copper spray, but not this time. No leaks.
danstr6
I always start in the middle and work my way out. I learned that many years ago from a master mechanic. I also always use brand new grade eight hardware including lock washers. Never had a problem. Good luck and godspeed.
T
Tinster
<span style="color: #990000">Sound advice. Finger tighten first and then
gradually tighten all in similar fashion akin to tightening
down lugnuts on a wheel. A little here, a littler there-
until uniformity of torque is attained.
Even the Tinster managed this task on the first attempt!!
regards,
Tinster</span>
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
B TR6 Anyone know where to get a decent Exhaust Manifold for 72 TR6 [dual] Triumph 2
B TR6 TR6 decision on header/manifold/exhaust Triumph 4
S TR6 71 tr6 exhaust manifold options Triumph 7
F GT6 TR6 dual exhaust manifold on GT6 engine? Triumph 2
71tr TR6 exhaust manifold TR6 Triumph 1
P TR6 76 TR6 Exhaust Triumph 6
Scotsman TR4/4A Can the TR6 exhaust go on a TR4A Triumph 5
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
D TR6 76 TR6 Exhaust Installation Triumph 3
T TR6 TR6 Monza exhaust - all that and a bag of chips? Triumph 41
TR6oldtimer TR6 73 TR6 Exhaust mounting question Triumph 4
I TR6 tr6 exhaust Triumph 17
E TR6 TR6 "Tuned" Exhaust Header Triumph 8
N TR6 74 TR6 Exhaust bracket for OD. Triumph 2
hondo402000 TR6 Monza exhaust modified for TR6 Triumph 0
roofman TR6 TR6 Exhaust system ideas NOW WITH A PICTURE !!!!! Triumph 39
A TR6 Bell Stainless Exhaust System,tr6 ?? Triumph 7
ScottTR6 TR6 TR6 exhaust Triumph 4
Aeroken TR6 TR6 Exhaust System Mounts Triumph 2
T TR6 TR6 Exhaust Triumph 7
mabbott TR6 TR6 exhaust paint....recommendation Triumph 4
7 TR6 Hi From Tx/Direction needed on TR6 Points/Exhaust Triumph 3
V TR6 Has anyone made a custom TR6 exhaust? Triumph 11
T TR6 72 tr6 exhaust system Triumph 18
G TR6 Interest in TR6/250 Ansa exhaust Triumph 3
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
