TR6 TR6 Brake caliper part.
TR6oldtimer
OK, this part is one of four that came in a kit from Moss. I am assuming it is part of the anti-squeal setup, but I do not have a clue as to how it is attached.
I am guessing the end tabs fit under the pins, with the center bar extending over the disc pads toward the disk.
By they way, did you know that the calipers were originally red on a '73?
houleyh
If I remember well, these spring are located on the top and bottom ends of the calipers. When in place, they put pressure on the pads to avoid ratteling?
Please correct me if I'm wrong so we could help this gentleman.
Thanks
Gliderman8
Were these springs original equipment? When I rebuilt my '73 TR6 calipers, these springs were not there.
BobbyD
Ray........it might be worth a call to Moss to ask them where they go. Here's the link to the Buckeye Site where they give a detailed write up on rebuilding the calipers. Nothing like that in the write up. I also couldn't find that part in either the TRF Blue Book or the Haynes manual.
TR6oldtimer
TR6oldtimer
Thanks guys. The springs fit over the brake pads to hold the anti-squeal plate in place. (I think)
Brosky
Ray,
You are correct. If and when those springs get broken the high pitched squealing starts along with the awful rattles when you hit a bump.
TR6BILL
Ray, someone got to those calipers and did the bling thing. They were never red, like mine were never yellow, till now.
Maybe Brosky's were red.... :devilgrin:
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
PatGalvin TR6 Need TR6 Brake Caliper Brackets Triumph 15
I TR6 TR6 - how many brake caliper shims? Triumph 26
S TR6 tr6 brake caliper rebuild Triumph 3
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
J TR6 TR6 Brake Question Triumph 1
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J TR6 TR6 Brake Pad Shims Triumph 1
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
A TR6 '73 tr6 passenger front brake dragging Triumph 2
C TR6 TR6 with dot 5 brake fluid Triumph 8
sundown TR6 1973 TR6 brake booster hose Triumph 7
smaceng TR6 TR6 brake pressure balance valve Triumph 2
D TR6 76 TR6 New Brake Bleeding Triumph 4
D TR6 76 TR6 Rear Brake Installation Triumph 17
D TR6 76 TR6 Brake Servo Triumph 2
D TR6 76 TR6 Rear Right Brake Line Triumph 8
bobh TR6 TR6 Brake Upgrade Triumph 19
W TR6 TR6 brake pedal drip Triumph 12
D TR6 TR6 Puddle of Brake Fluid on the floor Triumph 8
M TR6 Tr6 Brake Pull Triumph 6
BobbyD TR6 TR6 and other TRs - Brake Light Switch Alternative Triumph 7
sundown TR6 TR6 e-brake Triumph 2
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
hondo402000 TR6 71 TR6 Brake warning light and oil pressure light Triumph 6
T TR6 TR250/TR6 - Improving hand brake mech advantage Triumph 11
J TR6 70 TR6 Brake Booster Triumph 4
hondo402000 TR6 TR6 power brake bleeder Triumph 10
Phil73 TR6 TR6 brake issues Triumph 13
Z TR6 TR6 Brake Issue Triumph 8
wangdango TR6 TR6 brake servo rebuild kit? Triumph 2
I TR6 TR6 brake squeal Triumph 8
bigbadbluetr6 TR6 TR6 Brake Problems Triumph 6
mabbott TR6 Brake fluid in 73 TR6? Triumph 6
T TR6 Anyone have a spare TR4/TR6 brake master lid? Triumph 4
Brosky TR6 Really BIG Brake Kit for TR6 Triumph 15
I TR6 A few dumb TR6 brake questions Triumph 9
TR6oldtimer TR6 TR6 brake calipers Triumph 6
TR6oldtimer TR6 TR6 Hand Brake Install Triumph 2
I TR6 Rear brake drum temperature TR6 Triumph 13
hondo402000 TR6 Front Brake issues TR6 Triumph 2
hondo402000 TR6 figured out my low brake peddle problem TR6 Triumph 1
hondo402000 TR6 TR6 rear brake rebuild Triumph 10
I TR6 69 TR6 brake booster Triumph 2
T TR6 Any tips for replacing TR6 rear brake lines Triumph 10
B TR6 TR6 Disc Brake rattle Triumph 2
AngliaGT TR6 Found the TR6 Brake Problem Triumph 5
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
