TR4/4A TR4A Front Coil Spring Replacement
r66
I broke the left front coil spring on my TR4A. Reading the manual, replacing this looks like a manageable task with a spring compressor (correct???). The Moss catalog references both a "short" and "long" spring, although only the long is available. VB doesn't specify any difference, only referencing one kind.
Why the difference, and is the Moss "long" the one I want? I am not looking to change the ride or handling. I'd like it to be "stock".
Thanks-Ron
T
TRDejaVu
Just remember, that after the driver, the coil springs are the most dangerous part of the car; lots of stored energy wanting to escape (into you). That said, with care, it is a very manageable job.
MGTF1250Dave
Aloha Ron,
TR4A I believe all have the longer 11" spring. The earlier cars 2, 3 & 4 used a shorter 9.75" spring and an aluminum spacer. The combined height of the two pieces is 11", so some of the earlier cars are using the longer springs. The spacer in above the spring. The change over to the long springs seems to have been at CT29985. You nay be able to see if there is a spacer in your spring but it may be difficult.
The job of replacing the spring is not that difficult. However you need to be very safety conscious when unloading the spring compression.
Lionheart
I just happen to have a pair of what I believe to be original TR4 springs (a failed experiment with correcting the Spit front end height) that I am not going to use.
They measure ~9.75" unladen. The outside diameter is 4", and they have exactly 8 coils in each spring. I bought them on Ebay as "TR4 springs".
They look pretty good...if you want them, let me know and we can work something out. If you want to buy new, no biggie...just thought I'd offer.
Len
KVH
I replaced my springs in my 4A.
With all that comes apart when replacing the springs, I went ahead and replaced the tie rods, ball joints and all front bushings.
The Moss compressor worked fine.
Pressing in the new lower bushings was somewhat tedious. Applying correct torque, etc. was also no easy job in the spaces given, plus some ambiguity in the manual.
I recommend the urethane bushings for the upper wishbones; not the rubber ones.
Remember to closely follow the manual on removing the front springs. The six inch bolts, short block of wood, the whole bit, is all well worth the time to read and follow.
My experience was very positive: Smooth, soft and quiet ride.
Good luck.
kc_doyle
This might be the proper place for this. I don't have the book for my 71 Spit and I'm wondering if the front springs are a bit saggy. What would be the propper hight for them? Anyone?
Lionheart
Interesting...the usual complaint is that "the front of my spit is too high".
I replaced the front springs in my 77 1500 with earlier (shorter) ones. I have the unladen measurements written down...will look tomorrow. Cannot take the laden measurement right now...car is on jackstands undergoing several improvements at the moment. Check out this link for some more Spit spring info.
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
Popeye TR4/4A TR4A front frame reinforcement / parts don't fit Triumph 6
Popeye TR4/4A TR4A front suspension quesions Triumph 19
T TR4/4A Who is running Good Parts front springs on their TR4a? I have a ride height question. Triumph 1
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
M TR4/4A TR4A & 250 front bumper guards Triumph 5
GlennG TR4/4A TR4A Front Valances - How do they fit? Triumph 3
fpstude TR4/4A Front lower suspension brackets - TR4A Triumph 14
J TR4/4A TR4A Front Suspension reinforcement brackets Triumph 4
T TR4/4A TR4A - grille to front valence Triumph 3
M TR4/4A TR4A Front Suspension Bracket Triumph 3
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
glemon TR5/TR250 Lowering TR4A/250/6 in the front Triumph 13
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
Stinger TR4/4A TR4A Front Badge Quality Triumph 6
Darrell_Walker TR4/4A TR4A front sidelamp trim ring Triumph 4
Stinger TR4/4A TR4A Front Lower Valance Panel Triumph 2
Zimmycobra TR4/4A TR4A Front ride height revisited Triumph 24
Stinger TR4/4A TR4A Front Suspension Rebuild Triumph 26
KVH TR4/4A TR4A Front Suspension Triumph 2
T TR4/4A Once more - with feeling - Tr4a front suspension Triumph 10
T TR4/4A Correct front radiator tray for TR4a sway bar? Triumph 6
R TR4/4A TR4A Front lower Apron Triumph 2
T TR4/4A TR4A front rotor questions Triumph 11
T TR4/4A Removing TR4a front rotors Triumph 5
T TR4/4A TR4A front floor - patch or bolt new ones on? Triumph 3
L TR4/4A 66 tr4a front caliper rebuild...tips? Triumph 4
WME TR4/4A TR4A Front and Rear Shock Part Numbers Triumph 1
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
