TR4/4A TR4 ignition timing
bluemiata90
I just purchased a 65 TR4 that hasn't been running for several years. Prior to being stored, the head had been rebuilt and replaced (hopefully timing chain replaced correctly). After doing all the things you need to do to start an engine after a long storage, I fired it up. It started almost immediately and after a little fine tuning stayed running for me to drive it, but it really doesn't run smoothly, so I'm attempting to adjust all the needed settings. The problem is, setting the ignition timing correctly. I can get the timing hole lined up with the marker, but the #1 piston does not seem to be at TDC and the distributor rotor is slightly off the #1 plug hole. If I move the crank about 1/4 turn further, the piston reaches TDC and the rotor lines up perfect with the #1 plug hole. Is this normal and should I just paint another mark on the crank pulley and adjust it to that mark. Also, how do I figure out the advance degrees to set it at. If anyone can help me I'd greatly appreciate it. /ubbthreads/images/graemlins/confused.gif
scott
Geo Hahn
[ QUOTE ]
Is this normal
[/ QUOTE ]
No
[ QUOTE ]
...should I just paint another mark on the crank pulley and adjust it to that mark.
[/ QUOTE ]
That should work. For advance try about 3/8" on the crank pulley (using your new mark). That's close enough to 5 degress that you should be able to dial it in from there.
KVH
I have two suggestions here:
First, let's assume the hole is correct. The rotor always looks a little different than the manual says. I'm not saying it's right on your car, but I'd suspect that only after you're certain you correctly tuned the car.
Make sure you performed a static timing like the manual says. I'm sure you must know the drill.
If not, just use a wire and light bulb. That's what the old Chilton and other manuals recommend. You can use your turn signal bulbs if you don't have an extra one.
Do this only after you've properly set the point gap with a feeler gauge--carefully.
Pull the crank toward you until the marker is lined up with the hole. Then, with the ignition key turned on, and with a wire connected to the bulb, coil and ground, all at the same time (I usually touch the bottom of the bulb to the timing cover bolt, one end of the wire to the bulb housing and the other to the connector on the distributor side of the coil), rotate the distributor until the points just "open," meaning the bulb lights up. The bulb should just come on. Now tighten the distributor up so it won't rotate. Then, to get 4 degrees BTDC, use the adjusment dial on the distributor. Your manual should explain all of this, and the distributor shows you which way to turn the dial to advance or retard.
Static timing is best, and after you're done you can check it with a timing light if you really want to, but that shouldn't be necessary.
OK, that's my first suggestion. Proper point gap and timing.
My second is to make darn certain you have four good plugs, a good distributor cap and, most importantly for rough running, good plug wires and no "shorting out." Make sure none of the rear boots on the plugs are too close to any metal, such as the fuel line or any other steel. I've seen that be a problem due to the design of the fuel lines and other equipment on TRs. Bad wires or "arcing" from the plugs will ruin a car's performance.
Good luck.
TR4
My mark on the pulley is off 180 degrees so I have to time using the static method and the car runs great. By chance, the pulley has a fracture so I have to change it which will let me get the timing mark corrected. From what I can see, the timing mark should set opposite from the key on the crank. Nothing in the manual to tell where it goes when reassembling.
bluemiata90
bluemiata90
Thanks for the replies. I'm going to try and set the timing at the mark I made with the piston at TDC and the rotor inline with the #1 plug. I purchased a advanced unit off of ebay and won't be able to see if this setup works until I can replace the old advance(it wouldn't move at all, finally broke it after 2 days of trying to move it). I'm sure that was also part of the problem. Anyways, thanks again. I'll let you know how it turns out.
Webb Sledge
Are you sure the distrubutor gear isn't 180 degrees out? The car will run with it out that much, but it will act a bit wierd. I made that mistake on my car. Easy fix though.
Kurtis
Assuming valves and point gap are set correctly, here's what I do (and it has always worked well for me)... Time for maximum RPM with engine at fast idle (1500-1800 RPM), note the RPM, then retard the timing until the engine speed drops approximately 100 RPM. That should get you in the ball park. Next, drive it, and listen for pinging during acceleration in third or fourth gear. If you don't hear any pinging, advance the timing until you hear slight pinging, then retard slightly. If you hear pinging, retard the timing in small increments until it goes away.
Because of the unpredictable operation of the centrifugal and vacuum advance mechanisms on the TR4, I don't think it's possible to time them with a timing light.
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
Kirk_Fisher TR4/4A TR4 ignition woes Triumph 7
Mark_Barton TR4/4A Converting to ballasted ignition? '62 TR4 Triumph 8
T TR4/4A Ignition light on TR4 stays on. Triumph 5
TR4 TR4/4A TR4 Ignition Switch ??? Triumph 2
TR4 TR4/4A TR4 Won't start using the ignition key !!!!! Triumph 3
Kurtis TR4/4A TR4 Ignition Warning Light Triumph 6
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 2
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech Issues with Distributor--TR4 Triumph 13
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
