TR4/4A TR4 Ignition Warning Light
Kurtis
Greetings...
The ignition warning light on my TR4 has never worked. I decided to try to track down the problem this evening. Using a voltmeter, I determined that I don't have a circuit connection between the control box (terminal D) and the lamp. There is a brown/yellow wire on the lamp base that disappears into my wiring harness, and then a single brown/yellow wire connected to terminal D on the control box (that I assume comes from the generator). The wiring diagram would seem to indicate two separate brown/yellow wires connecting at terminal D (one from the generator and one from the warning light). My wiring harness looks fairly unmolested from the lamp to the control box. Is
there supposed to be another wire?
BTW, when I do connect a length of wire from the lamp to the control box, it seems to function correctly (on at ignition on and low rpms, and off as rpms increase). The white wire from the light base to the ignition switch is in place and connected properly.
TIA
Kurtis
Webb Sledge
I don't have Bentley manual or a wiring diagram for the TR4, but I assume you do (if not, you should get one. Very helpful...). Does the diagram show another wire? If so, there's your culprit.
Sorry I couldn't be of much help. I think I somehow managed to type a paragraph without saying anything.
piman
Hello Kurtis,
do you have a WL terminal on the regulator?, if so the warning light (brown\yellow) wire should be connected there.
Alec
Kurtis
Kurtis
I'm not sure what you mean by "WL" terminal. Regardless, I have it sorted out (sort of). I ended up running a new wire from the control box to the lamp base. I could find no evidence of a seperate wire branching off from the wiring harness near the control box, and I decided not to start unwrapping my harness and look for the mystery wire.
I'm now confident that there should be a seperate wire connecting to terminal D, I just can't figure out where the other end went. /ubbthreads/images/graemlins/smile.gif
Thanks,
Kurtis
piman
Hello Kurtis,
WL is a terminal marking, as B, D, and F.
The diagram on my Triumph 2000 shows the warning light being connected to WL and not D. I don't know why there would be a seperate terminal but it would seem that there may be some fault created if you do use the D terminal.
Alec
Kurtis
Kurtis
[ QUOTE ]
Hello Kurtis,
Alec
[/ QUOTE ]
Oh... okay. There is no WL terminal on the TR4 control box. The wiring diagram clearly shows it connected to the D terminal (there are two connection points - a large and a small spade connection). I just wish I knew where the heck the other end of the original wire from the warning lamp went. Like I said, it doesn't look like my wiring harness has been apart in that area... but who knows.
Thanks again for your reply.
Kurtis
Geo Hahn
[ QUOTE ]
...I just wish I knew where the heck the other end of the original wire from the warning lamp went. Like I said, it doesn't look like my wiring harness has been apart in that area... but who knows...
[/ QUOTE ]
I have always thought that of Superman's powers, Xray vision would be the most useful to the TR owner.
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
Kirk_Fisher TR4/4A TR4 ignition woes Triumph 7
Mark_Barton TR4/4A Converting to ballasted ignition? '62 TR4 Triumph 8
T TR4/4A Ignition light on TR4 stays on. Triumph 5
TR4 TR4/4A TR4 Ignition Switch ??? Triumph 2
TR4 TR4/4A TR4 Won't start using the ignition key !!!!! Triumph 3
bluemiata90 TR4/4A TR4 ignition timing Triumph 6
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
