TR4/4A TR4 fan extension and crank bolt length
Alfred E. Neuman
I have a '63 TR4 that I'll be restoring in the near future. The car has some modifications that I'm going to put back to original and I'm starting to collect parts for the project. I'm hoping for some information from those with a TR4 and access to a tape measure. And if anyone has any of the parts they're willing to sell, we'll work something out.
The car is a mid '63, CT 24299 O, factory Surrey top. I'm going to drive it while I gather parts and funds, then do a frame-off back to factory original with a few very minor tweaks. I plan on a Revington fast road suspension and frame reinforcing. Everything else will be back to stock except for building the engine induction and crank case ventilation to a slightly earlier spec. The car will be a club rally and touring car for the wife and I. I drive my TR's A LOT, so I'm building for robustness and longevity over finicky hand grenade.
1. The car has a thin belt conversion and engine fan removal, along with an alternator conversion. I plan on going back to the stock wide belt, with engine fan (likely will deviate a bit here and install the plastic 8-blade fan). I need to know the extension length and crank bolt length for a TR4 so I can shop the ebays. I can't find the extension length anywhere, but have found a measurement of 189mm for the crank bolt from the shoulder of the bolt head to the end of the shaft.
I'm going to need the fan hub, wide belt pulley, extension, and crank bolt. I'll buy a new fitting kit from TRF.
2. With the alternator conversion, the bracket for the generator mount on the block has been modified to move the rear tab forward. I'll need a used or new mount. I plan on going back with a generator.
3. Tube shock conversion on the rear. I'm going back to levers. The problem I have is that my car originally came with the deep dish springs that needed the spacer block between the spring and clamping plate. It currently has the earlier TR4 springs without the spacer block, but the spring clamping plate is the one without the lever shock link mounting holes. I plan on using the earlier springs and just getting the earlier spring clamping plates with the mounts. I'll need a left and right. I think these are the same for all Girling TR3's and early 4's.
4. It has an HS6 carb setup. I like the carbs, but am wanting to go back to a little earlier set-up. I'd like to get a late TR3 or early TR4 intake manifold and go to H6 carbs. I know the HS6 are "better", but I like H6 as I've dealt with them for years on my TR3. I'm also planning on getting an earlier valve cover and draft tube and eliminating the breather from the VC to the carbs. So I'll need an earlier intake manifold, VC (I'll buy a new alloy if needed), and draft tube and all attachments.
Any help is appreciated,
Robby
TR4nut
Robby-
sorry don’t have the dimension but if you go with the yellow fan you need to buy the TR3 hub and bolt. It will be 3/4” shorter than the TR4 hub which gives you the room for the thicker plastic fan.
Randy
Alfred E. Neuman
Alfred E. Neuman
Randy,
Thanks for the info. I was under the impression the yellow fan was plug-and-play. I'll likely go with the original style fan and install an aux. electric fan that's just switched under the dash for use when it sits at idle for a long time. I never had any overheating issues with my TR3 in the hottest Georgia weather, so I'm sure a 4 with the original fan and a new rad, plus a newly rebuilt engine that's been tanked will stay cool.
Mink
I can get you the extension length from my car when I get home later. It's an early '62 (9796L) and I am running the yellow fan on the original extension with no clearance issues.
Mink
In the meantime, here's a photo of it before it went back in the car.
TRMark
Bronze
I have what you need, but I am a long ways away. Might want to check with Marvin Gruber. I have pictures and descriptions of modifications made to the tr4 for rallying, I received them from Ian Cornish who owns a works rally car. pm me your email and I can send them.
malbaby
Robby, I can appreciate your desire to return to factory original.....pardon me for my opinion......"I'm building for robustness and longevity over finicky hand grenade". .......and you want to revert to generator and reinstall the fan extension as original.;)
Alfred E. Neuman
Alfred E. Neuman
Ha! I get it, but I put tens of thousands of miles on my TR3 with bone stock everything. I had to rebuild the generator once due to a growling bearing, other than that it hummed along just fine for all the years I owned it. :eagerness:
As to the fan, I just don't like the idea of not having a mechanical fan where one was supposed to be. I plan on having the machine shop balance the crank with the hub and extension. Also plan on having the flywheel and clutch balanced separately so it doesn't throw off anything when I have to replace the clutch.
Willie_P TR4/4A Fan Hub Extension removal early tr4 HELP Triumph 9
T TR4/4A TR4 Fan Extension Dog Bolt Torque Triumph 4
J TR4/4A TR4 Fan Hub Extension replacement Triumph 4
T TR4/4A TR4 Engine - Fan Hub Extension Triumph 4
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
E TR4/4A TR4 Radiator position with Macy's garage Fan Triumph 6
Geo Hahn TR4/4A TR4 Fan Post Mortem Triumph 11
Geo Hahn TR4/4A TR4 Fan Alternatives Triumph 7
KVH TR4/4A The Yellow Fan on a TR4 Triumph 4
T TR4/4A Upgrading the TR4 stock fan Triumph 20
KVH TR4/4A TR4 Motor Mounts/Fan Pulley Triumph 2
Geo Hahn TR4/4A Bad Break - Ouch! TR4 Fan Triumph 11
E TR4/4A TR4 Fan Hub Triumph 4
SCguy TR4/4A Yellow plastic fan in early TR4? Triumph 8
M TR4/4A TR4 - Fan Pulley wobble question Triumph 5
M TR4/4A TR4 Fan Belt Triumph 13
D TR4/4A TR4 Fan [Yellow Plastic] on a TR3? Triumph 8
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech Issues with Distributor--TR4 Triumph 13
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
