TR4/4A TR4 Fan Post Mortem
Geo Hahn
To paraphrase Oscar Wilde -- lose one fan, that's misfortune. Lose a second fan and it begins to look like carelessness.
So my question (apart from the ones I asked in another thread) is -- why did this happen again?
The first fan was the original 44 year-old-part so naturally I just chalked that up to age. It may have even suffered some trauma the week before the failure when I drove thru a dry wash and scooped up a load of sand.
The second was a used fan that appeared fine. I balanced the fan itself but did not remove the hub from the engine and balance the pair as a unit.
Bad Karma? Failure to balance? Symptom of something else?
HerronScott
Geo,
Thanks for the pictures. I was going to ask in your other thread as I had never seen a broken one and wanted to see where they failed.
Sorry can't help on the why though since I can't imagine what would cause the break across the fan blade like that.
Scott
Geo Hahn
Geo Hahn
FWIW -- In both cases it appears that the fracture went from right to left (as viewed in the photo) and the last bit to let go (showing signs of flexing & work hardening) was the left hand edge.
vivdownunder
It's a problem that's been known for 51 years. Fan blade failures ruined the factory TR3S campaign at Le Mans in 1959 when two cars had to retire with damaged radiators. Valuable time was lost removing the fan from the third car, although its eventual DNF was due to a lack of oil pressure.
Viv.
DNK
George, you been running your car at Le Mans again?
Andrew Mace
Viv.
All true. However, the TR3S cars were running much higher speeds (and with a very different engine) than any of us is likely to encounter. Also, it is not always mentioned that competitions manager Ken Richardson had fought NOT to have fan blades installed on the Le Mans cars but was overruled by someone higher up. Turned out he was right. :wall:
angelfj1
Geo, one theory that I have heard is that the outer most rivit loosens allowing cyclical movement of the blade at that point. This continues until the blade fatigues at that point and a crack starts.
TexasKnucklehead
Is the angle (pitch) of each blade exactly the same?
Those failures look very much alike. Is that top rivet loose now?
FWIW, I looked very hard at the pictures, but can not see any carelessness.
KVH
George, I'm shocked by what I see and what appears to be a pattern.
Your post about the mysterious happenings to your TR4 is precisely your 4440th post over a period of many years. In addition, your 4-bladed fan, which fastens with 4 bolts, appears to have failed in precisely the same spot, in each case with the culprit being the 4th rivet at the top. In addition to these painfully eerie revelations, you chose to share with us that your fan was 44 years old.
I'm sorry, but I'll have to look into this much deeper and report back with my further conclusions.
hondo402000
Well you can grind off the rivets, make new blades from some new AL and rivet them back on. I am sure you can get rivets somewhere, heat them up with a torch and pean them down, or bolt them with nylocks, they probably used rivets instead of bolts because rivets were cheaper
Hondo
Geo Hahn
Geo Hahn
hondo402000 said:
Well you can grind off the rivets, make new blades from some new AL and rivet them back on...
That was my wife's suggestion though she pointed out that I actually have 3 spare blades to choose from... i.e. remove the best remaining blade from one fan and rivet it on in place of the broken blade on the other fan.
I may actually try that though for now I have sourced a replacement through the kindness of a Forum member.
I did just now check the rivets and it appears to me that they are all nice and tight.
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
E TR4/4A TR4 Radiator position with Macy's garage Fan Triumph 6
Willie_P TR4/4A Fan Hub Extension removal early tr4 HELP Triumph 9
Geo Hahn TR4/4A TR4 Fan Alternatives Triumph 7
KVH TR4/4A The Yellow Fan on a TR4 Triumph 4
T TR4/4A Upgrading the TR4 stock fan Triumph 20
T TR4/4A TR4 Fan Extension Dog Bolt Torque Triumph 4
KVH TR4/4A TR4 Motor Mounts/Fan Pulley Triumph 2
J TR4/4A TR4 Fan Hub Extension replacement Triumph 4
Geo Hahn TR4/4A Bad Break - Ouch! TR4 Fan Triumph 11
E TR4/4A TR4 Fan Hub Triumph 4
T TR4/4A TR4 Engine - Fan Hub Extension Triumph 4
SCguy TR4/4A Yellow plastic fan in early TR4? Triumph 8
M TR4/4A TR4 - Fan Pulley wobble question Triumph 5
M TR4/4A TR4 Fan Belt Triumph 13
D TR4/4A TR4 Fan [Yellow Plastic] on a TR3? Triumph 8
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
