TR4/4A TR4 Fan Extension Dog Bolt Torque
T
TRDejaVu
I know that I have asked this before and I know that I wrote it down somewhere. I can't find it on search.
What is the torque setting for this bolt?
Thanks
KVH
I wish I could quote something, as I just went through all this. I lined up the pulley with the fan extension per spec, held the crankshaft from turning (my oil pan was off so that was easy), then tightened the dog bolt with torque wrench to about 75 lbs. After what I went through to get that beast off (hours of antics), I guess I was too afraid of stripping the threads to go tighter. Someone on this board told me to tighten it to 100 lbs, but that spec does not appear in the Manual. The manual just says to tighten until the starter dogs line up to "ten minutes to four." That doesn't seem to mandate a torque of 100 lbs, but maybe others have more information. In addition, tell me if I'm wrong, but I don't think my TR4A dog bolt has any starter dogs.
prb51
Pretty much like Kentville....used an impact wrench and swag'd about 75 ft lbs. No problem for 4k miles.
Just did the same with the bolt that replaces the dog bolt when not using the fan, hasn't flown off yet.
T
TRDejaVu
Last time I did it I had the sump pan off and was able to lock the crank. This time I don't and I don't have an impact wrench either. I have made up a bar that picks up on the fan attach bolts and will try to lock it up.
T
TRDejaVu
Couple of pics of my jury rigged dog bolt lock bar; simple and it worked great.
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
Willie_P TR4/4A Fan Hub Extension removal early tr4 HELP Triumph 9
J TR4/4A TR4 Fan Hub Extension replacement Triumph 4
T TR4/4A TR4 Engine - Fan Hub Extension Triumph 4
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
E TR4/4A TR4 Radiator position with Macy's garage Fan Triumph 6
Geo Hahn TR4/4A TR4 Fan Post Mortem Triumph 11
Geo Hahn TR4/4A TR4 Fan Alternatives Triumph 7
KVH TR4/4A The Yellow Fan on a TR4 Triumph 4
T TR4/4A Upgrading the TR4 stock fan Triumph 20
KVH TR4/4A TR4 Motor Mounts/Fan Pulley Triumph 2
Geo Hahn TR4/4A Bad Break - Ouch! TR4 Fan Triumph 11
E TR4/4A TR4 Fan Hub Triumph 4
SCguy TR4/4A Yellow plastic fan in early TR4? Triumph 8
M TR4/4A TR4 - Fan Pulley wobble question Triumph 5
M TR4/4A TR4 Fan Belt Triumph 13
D TR4/4A TR4 Fan [Yellow Plastic] on a TR3? Triumph 8
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
