TR4/4A TR4 Dash Support
E
eyesie
Hi
This might seem like an odd question, but does the "horseshoe" dash support bracket sit directly on the metal or do I have to wait until the carpet / padding is installed?
Thanks
Alan
Geo Hahn
The support is bolted directly to the floorboards (captive nuts are welded underneath). The carpet will be shaped to go around the supports.
That said, depending on your carpet kit you may find it easier to put the tunnel carpet in place before installing the support. Some kits have 2 pieces over the tunnel that meet under the support but as I recall some have a one-piece tunnel carpet that may be difficult to install with the support bolted down.
charleyf
I agree with George that the tunnel carpet should go in first. This is even with the two piece kit for the tunnel. If you tried to put the dash support on top of the carpet you would find that there isn't enough clearance to fit the support plus the radio plate all under the dash.
Charley
rnpennington
I just recently re-did my entire dash. I put the tunnel carpet in first, then the dash support. You will probably find you will have to put the dash support in at an angle and then push it up, if it has been out for any length of time, because it is a support and the dash will drop some.
JimTR4 TR6 TR6 dash support in a TR4? Triumph 23
doughairfield TR4/4A Dash Support Bracket for TR4 Triumph 15
Geo Hahn TR4/4A TR4 Dash Support Triumph 1
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Rut TR4/4A TR4 wood dash Triumph 26
SpeedyG TR4/4A TR4 vs. TR4A metal dash panel Triumph 5
J TR4/4A TR4 Dash Handles Triumph 3
Zitch TR4/4A Early 63 TR4 [CT16438L] Dash refresh Triumph 3
M TR4/4A Crash pads for TR4 dash.....best place to buy? Triumph 7
JimTR4 TR4/4A TR4 dash pads Triumph 4
R TR4/4A Recommendations for Wood dash 1962 TR4 Triumph 5
E TR4/4A TR4 Wooden Dash Facia vents Triumph 13
T TR4/4A TR4 early dash Triumph 7
KVH TR4/4A New Dash Top TR4 Triumph 2
J TR4/4A TR4 reproduction dash pad Triumph 3
bgbassplyr TR4/4A TR4 dash..... Triumph 2
T TR4/4A Ideas on restoring the TR4/6 center dash supports Triumph 6
T TR4/4A TR4 Wooden Dash Triumph 19
SCguy TR4/4A TR4 Under the Dash Vent Question Triumph 6
pa297pass TR4/4A TR4 Wooden Dash Triumph 13
SCguy TR4/4A TR4 Dash Request Triumph 5
SCguy TR4/4A 62 TR4 dash question Triumph 7
D TR4/4A TR4 Dash Lights Triumph 7
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
