TR2/3/3A TR3 Piston Sets
RedTR3
I am curious why Moss does not sell 83 mm piston sets (they only list complete piston/liner sets). Is it a quality issue or just possibly lack of a market for these? VB does list them in their catalog.
TomMull
No idea really but my guess would be lack of market. Considering the work involved in changing pistons in these wet liner engines and the somewhat limited scenarios where new or bored liners would not be also advisable, lack of demand seems likely. When NOS sets come available, they seem to attract very few bids. New sets were available from Morse some time ago: 814000. They were also available from general aftermarket suppliers, (Hastings and Federal Mogul, for example) although I have not checked for some time.
Tom
DornTRoriginal
I would agree there is a lack of interest, if your going to do the work of a "meticulous Assembly" why settle for something that is marginal and out dated? I got my piston set from British Frame and Engine have not had the pleasure of driving it yet but I can't wait!
RedTR3
RedTR3
The machinist who is rebuilding my engine would prefer to bore the liners "in place" rather than removing/replacing them since the liners have been well-seated in the block for many years. Thus I am just assuming that I need to stay in the 83 mm range, maybe that is a poor assumption on my part. (have not reached that point in the rebuild yet).
TomMull
I'd get a second opinion here, for sure. This may be possible but does not sound right to me. You need to remove the jugs to replace the figure 8 gaskets and rely not on age and scuz for a seal. Any boring enlarges the bore and you cannot go back to std without inserting sleeves, totally impractical here. The block needs a thorough cleaning too, particularly after machine work.
Tom
DornTRoriginal
I AGREE, probably not going to bore just hone them maybe? I have a copper head gasket (83mm) if you want it let me know, I have no use for it.
Jayplum
I can't imagine the reasoning of all the metal shavings being collected in the block and then attempting to clean them out. I would definitely get a second opinion.
charleyf
Being able to remove the old liners allows one to "get inside" the block and really clean it out. This will help for cooling in the future. I found a lot of buildup, especially in the rear of the block. It sounds like your mechanic is just not experienced with liner type motors.
If you bore the old liners then you will likely need to go up to the 86 mm. pistons. Though there may be some piston sets between the 83 and 86.
Charley
TFB
I cant imagine any experienced builder of these motors wanting to take that route unless the liners can be cleaned up with minimal honing (rigid clyinder hone) and original or new original size pistons can be used with new rings.
Even if you bore the liners oversize,and 83mm is available oversize, you still need pistons,pins and rings
The removable liners are of great benefit for rebuild ease .
Also hes not just boring but then finish honing,checking fit, and at what cost.
I would get best set of 86 mm ,disassemble to check clearances,wash everything with solvent,then soap and water,oil up, reassemble and install.
And I dont like three piece oil rings but thats another subject.
Tom
CJD
Find another machine shop. That one obviously wants to treat your engine like an American block with integral cylinders. You cannot count on crud holding a part while you machine it, and that is reason enough to run away from this guy.
You can easily machine the liners outside of the block...but once you price machining versus the price of a piston/liner set, you see why it is rarely done.
Jayplum
amen!!
Jayplum TR2/3/3A TR3 Piston Sleeves Triumph 36
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
A TR2/3/3A Tr3 / 4 piston clearances Triumph 7
doc50 TR2/3/3A TR3 Piston Surprise Triumph 18
MGTF1250Dave TR2/3/3A TR3 Piston Orientation Triumph 7
B TR2/3/3A TR3 piston/liner advice Triumph 5
Number_6 TR2/3/3A 89 mm Piston and Liner Kit for TR3 Triumph 5
T TR4/4A TR3 or TR4 piston replacement question Triumph 2
RedTR3 TR2/3/3A TR3 Carb Piston Damper Length Triumph 6
Tinkerman TR2/3/3A Piston Fun 60 TR3 Triumph 10
Tinkerman TR2/3/3A Installing Piston Liners 60 TR3 Triumph 6
L TR4/4A Looking for a TR3-4a 87mm piston & Liner Triumph 0
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
