TR2/3/3A Piston Fun 60 TR3
Tinkerman
I have the pistons in the block, everything is well lubricated and I tightened the rod caps a little at a time so they all got approximatly the same tightening. I kept turning the crank also. After the last tighening sequence I can barely turn the crank. If I go to the proper torque there is no way that I will be able to turn it over. BTW I am using The old timing chain and a very stout beefy pump wrench (adjustable wrench for you young guys)to turm it. Is this unusual, ususal or do I have a problem? I'm thinking that I might have the wrong inserts in it. Anyhow any thoughts would be very helpful.
Tinkerman /ubbthreads/images/graemlins/confused.gif
Bugeye58
Tinkerman, you need to recheck your bearing clearances. Either you have the wrong bearings, or there is dirt or contamination under the inserts.
Try tightening one rod at a time and see if that changes anything. If you can spin the crank until you tighten one that locks it up, you've at least isolated which rod is the problem.
Or, pull the bearings, mike the crank, and check the size on the back of the inserts.
Jeff
billspit
When I rebuilt my Nissan truck engine, I put a small gall on the very edge of the rear main bearing cap. It caused the bearing to squeeze down too much and would bind the crank. Ground it off and all was well.
Tinkerman
Tinkerman
well, guess who has to back and take micrometer reading 101 allllll over again! The way I figured it I needed the .020 bearings and I was wrong, I needed the .010 bearings.
Thanks for help fellows, all fixed and turning the way it should now.
Tinkerman
martx-5
I use Plastigage to check bearing clearances. In this case, I can't imagine how squished the stuff would have gotten. /ubbthreads/images/graemlins/eek.gif
Glad you found out what the problem was.
/ubbthreads/images/graemlins/driving.gif
Tinkerman
Tinkerman
You know, I forgot about the plasti guage. My engine guy even suggested that I try it and I have some in my toolbox, oh well it came out OK.
Tinkerman /ubbthreads/images/graemlins/grin.gif
TRTEL
I fear those .020 bearings might now be throw aways.
Tom Lains
TS 8651 & 58107
Tinkerman
Tinkerman
Tom, yes, I'm afraid you might be right, sigh. I was thinking I might be able to sell them on ebay but they looked a little the worse for wear. I may put them on with full disclosure and see what happens.
Cheers, Tinkerman
trfourtune
once a bearing has been installed, it cannot be re used for anything else. ie its used. you should never think that it is still new once it has bee torqued. the edges of the bearing crush where they meet and only can be used in your engine in the location it was first torqued. if you drop them on the floor and mix them up-they are now trash.
Rob
K TR2/3/3A Piston slap? Triumph 3
T TR2/3/3A valve guides and piston clearance Triumph 6
Simmo TR2/3/3A Something is eating away at my Piston Liners Triumph 15
D Separating the piston from the connecting rod. Spridgets 9
J Piston Coating Austin Healey 3
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
KVH General Tech Removing Piston Wrist Pin Triumph 2
sail TR4/4A Piston Ring Question Triumph 6
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
J TR2/3/3A 87mm piston ring gaps Triumph 15
Jayplum TR2/3/3A TR3 Piston Sleeves Triumph 36
M TR2/3/3A How many miles to seat piston rings? Triumph 4
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
BJ8Healeys Disc brake piston seals Spridgets 2
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
M TR2/3/3A Please Help ID This Piston Triumph 6
Got_All_4 TR6 Are these piston nitrated coaded Triumph 5
J TR2/3/3A 83 to 87mm Piston Considerations Triumph 7
Gerard 1275 piston ID Spridgets 2
HighAltitudeTR3 TR2/3/3A Piston Slap 👋 Triumph 12
M TR2/3/3A Sleeve and Piston Sizes Triumph 6
Got_All_4 TR6 Depth of the metering needle in the air valve piston Triumph 12
steveg Piston options for Healey Austin Healey 12
T TR2/3/3A SU Piston Drop Test Triumph 4
C TR2/3/3A Piston gap orientation Triumph 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
T General Tech Brake caliper - piston stuck Triumph 4
2billydavies TR2/3/3A need an educational lesson about piston rings Triumph 14
KVH TR4/4A Piston Size Measurement on Rebuild Triumph 4
Jake OD unit operating piston rings? Austin Healey 1
JPSmit Brake piston removal - McGyvered some tools Restoration & Tools 0
W TR2/3/3A Piston and Liner Triumph 2
tinman58 TR6 Piston clearance Triumph 4
T TR4/4A Overdrive piston is sticking Triumph 9
TomMull caliper piston tool Restoration & Tools 11
T General Tech How loose can a piston liner be? Triumph 2
busybrit TR6 AE Piston supplier, when you only want one ! Triumph 2
M Healey 100-4 Piston Crown Clearance needed to Cylinder Head Austin Healey 3
oxford piston rings Austin Healey 4
T TR2/3/3A caliper piston stuck Triumph 12
S TR6 Clutch slave piston shooting out during bleeding Triumph 8
RedTR3 TR2/3/3A TR3 Piston Sets Triumph 10
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
A TR2/3/3A Tr3 / 4 piston clearances Triumph 7
M Healey Overdrive Upgrade with Larger Piston & Stiffer Springs Pros/Cons? Austin Healey 12
