TR2/3/3A TR3 - Lower Fulcrum thread size
jcarr11
Restoring a '56 TR3. The threads on the lower fulcrum(s) are a little rough. Bought a 7/16-20 rethreading die and it seems to be too small.
Anyone know offhand what the threads are?
TIA
Jeff
TR3driver
Great Pumpkin - R.I.P
If you are doing a restoration, you should probably learn one of the tricks. Most (not all) of the nuts & bolts have a "standard hardware" part number consisting of two letters and 4 digits. You can look these up in the factory "Spare Parts Catalogue". Reprints are available, or
https://docs.google.com/open?id=0B2H2NJt34OffMWQ4N2EzZGQtNjc0Ny00YmE2LWFiN2UtZWYzMjNjNGFiYzY4
Then look up the number in the Standard hardware catalog:
https://docs.google.com/open?id=0B2H2NJt34OffMjJhY2YwZmQtYzgxNC00ZTk0LTk1YTUtZTIyZmU3ZTc1Y2M4
(Sorry the scans leave a lot to be desired, I'm slowly improving them. But they are usually legible if you zoom in far enough.)
For example, the nut for the lower fulcrum pins is TN.3210, which the hardware catalog reveals as a 7/16" UNF thin nyloc nut. (Which of course means that Shawn was entirely correct.)
J
jcarr11
Thanks Randall. I had the hardware catalog, but not the spare parts catalog.
Documentation for the TR3 sure is good compared to my previous restoration (Alfa Duetto).
Jeff
Kleykamp TR2/3/3A TR3 lower engine parts?? Triumph 2
T TR2/3/3A Vent hole in lower front valance of TR3? Triumph 7
J TR2/3/3A Urethane bushings for TR3 lower inner contol arms? Triumph 11
K TR2/3/3A TR3 ..front lower wishbone removal question.... Triumph 6
K TR2/3/3A TR3 Lower Bump Rubber Bolt Frozen Like its Welded Triumph 5
G TR2/3/3A TR3 lower outer trunnion Triumph 4
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
