Been trying to get my latest addition to the garage running correctly. It is a 1961 TR3 that had been in long term storage. I did all the basic stuff like lubing cylinder walls, cleaning points, changing plugs and wires. After a little fiddling it started but only runs on the front 2 cylinders. I adjusted the valves and check compression. Compression is all over the board between 150 and around 75. The back plug gets wet and black and #3 stays clean. I can start the engine and pull the back 2 wires with no difference in the engine sound. There is a good spark from each plug. The car had no air cleaners mounted when I pulled it from the storage locker. There is gas in the back float bowel and plenty of gas feeding it. Any ideas?
Thanks, Donnie
Thanks, Donnie
