TR2/3/3A TR3 engine ground
TFB
Can anyone tell me where the engine ground strap attaches to the engine and body or frame.
Thanks
Tom
TR3driver
Great Pumpkin - R.I.P
Should be a short braided strap from one of the timing cover bolts to one of the LH motor mount bolts into the frame. Here's a photo supplied by Don Elliott:
T
TFB
Thanks Randall(and Don).I am putting in starter and thought it went off one of the starter bolts.Perfect picture.Thanks
Tom
CJD
Hey, this thread reminded me of a question I've had for a while. The cable in this picture grounds the engine to the frame...and the battery is grounded by cable to the body...but is there supposed to be a cable between the body and frame??? My TR3 has none, so all I can figure is it's grounding through the body attachment bolts...
TR3driver
Just grounds through the bolts, AFAIK.
CJD
Interesting. I used some pretty heavy-duty paint on the body mounts during the restoration. I'll have to take at least one bolt out and remove the paint under it to ensure a good ground between the body/chassis. It makes you wonder if some of the other electrical issues in the threads on regulators/starters/etc. aren't related to poor grounds.
Platinum
Over the years it seems to me MOST of the electron gremlins can be attributed to faulty grounds.
T
TFB
And based on that I am also installing a #4 wire from starter bolt to bulkhead ground bolt,and the original strap,now that I know where it goes.
Thanks
Tom
CJD
Sounds like a good idea Tom! I thought my car was just missing a ground strap somewhere. All the body bolts go through rubber insulators on the TR. My car was the least corroded TR3 I have ever seen when it came apart for the restoration. Still, the body bolts were in terrible condition...the heads almost completely rusted off and all were frozen. It sounds like a body-to-chassis ground is a good modification.
TR3driver
I agree, but I've never seen a poor connection between body & frame.
If originality is not an issue, then I would suggest running a battery ground cable directly to the engine. Even without any bad connections, the factory setup adds some resistance to the circuit, which limits the current available to the starter motor. Lots of cars use a "2 headed" cable with tabs for connection to both the body and the engine.
martx-5 TR2/3/3A TR3 Engine Ground Strap Triumph 12
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
Pool Dad 1960 TR3 engine serial number Triumph 14
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
HalLucy Standard Vanguard Sportsman engine and the TR3 Other British Cars 7
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
Moosca TR2/3/3A "56 TR3 Engine Verification Triumph 17
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
W TR2/3/3A Novice TR3 Engine Rebuild Triumph 47
J TR2/3/3A TR3 engine build Triumph 12
doc50 TR2/3/3A How to verify TR3 engine numbers Triumph 20
6 TR2/3/3A Engine in my TR3 Triumph 15
M TR2/3/3A TR3 engine hood wanted Triumph 7
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
Kleykamp TR2/3/3A TR3 lower engine parts?? Triumph 2
Got_All_4 TR2/3/3A Tr3 engine trany pull Triumph 6
Brinkerhoff TR2/3/3A TR3 free engine parts to forum members Triumph 6
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
mt10flyer TR2/3/3A 1959 TR3 engine rebuild problems Triumph 14
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
5 TR2/3/3A TR3 engine building tips needed Triumph 5
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
D TR2/3/3A tr3 engine Triumph 6
H TR2/3/3A Cant get my Tr3 engine to start. any advice? Triumph 29
V TR2/3/3A TR3 Engine Noise Triumph 33
NutmegCT TR2/3/3A TR3 engine question Triumph 6
MGTF1250Dave TR2/3/3A Questions about Breaking in a refreshed TR3 Engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Rebuilt & Installed Triumph 7
O TR2/3/3A TR3 Engine Miss Part 2 Triumph 11
O TR2/3/3A TR3 Engine Miss Triumph 5
K TR2/3/3A TR3 Engine block marking? Triumph 4
G TR2/3/3A TR3 Rear engine seal issue Triumph 13
O TR2/3/3A TR3 engine removal Triumph 5
Bremer TR2/3/3A Hypothetical: Big bore TR3/4 engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Noise Identified Triumph 11
PatGalvin TR2/3/3A Engine Harness and/or Attachment Points for TR3 Triumph 10
MGTF1250Dave TR2/3/3A TR3 Engine Noise Up-date Triumph 11
C TR2/3/3A tr3 engine numbers Triumph 23
MGTF1250Dave TR2/3/3A TR3 Engine Hoisting Fittings Triumph 5
MGTF1250Dave TR2/3/3A TR3 Engine Noise Triumph 26
T TR2/3/3A TR3 floor replacement. Engine in or out? Triumph 3
K TR2/3/3A TR3@70mph engine seemed to "flatten out" or..... Triumph 10
A TR2/3/3A TR3 engine removal Triumph 9
