Took some advice here ans soaked all the cylinder walls with sea foam (my Favorite). The compression on all cylinders is now between 125-150. Put the plugs back in, fired it up and the same results. The back 2 cylinders are not firing. Valves are adjusted, good spark. Not sure about the fuel delivery though. The rear float bowel has gas and does not seem to be sticking open or shut. I don't know what to check next. Any Ideas?
Thanks, Donnie
Thanks, Donnie
