Tire size for wire wheels
gjh2007
Hello all:
Happy Holidays
I just picked up a set of wire wheels & hubs for my 250. I am currently running 205/70/15's on steel wheels, but I think they may be too wide for the wires.
I am looking for more of a classic look anyway & was wondering what people are running on their wires. I don't care about originality, (redlines), but am looking for a decent tire that will give good handling on a stock car, with uprated shocks, bushings and front sway bar.
Any help would be appreciated.
I will also need a set of knock offs if any one has some.
P.S. if I go a diff size I have a nice set of Pirelli 4000's that will be for sale.
kodanja
I went with original mitch. redlines>>>>
((Thanx Paul))
kodanja
LastDeadLast said:
205/70-15 on Dayton wheels. Lowered 1" and still no rubbing:
I wanna see that kids drivers licence!!!!....LOL /bcforum/images/%%GRAEMLIN_URL%%/driving.gif
yer car looks great!!
LastDeadLast
Thanks! I absolutely love the looks of wires on our cars.
I'm still wondering how my boy reached the pedals to pull the car out of the driveway!!! /bcforum/images/%%GRAEMLIN_URL%%/driving.gif
LastDeadLast
Andrew Mace said:
Key here is the width of the wheels themselves. If they're older 60-spoke, 4.5" wide, I wouldn't go much beyond the 165SR15 for them. If they're a later 72-spoke, 5.5" wheel, the 205/70R15 might be ok.
Very true.
martx-5
The rule of thumb is that the rim width must be at least 70% of the tire width. So, if you have a 5.5" rim, divide by .7, which is 7.86 x 25.4 = 200mm. You could get away with a 205.
If the rim is 6", then the math yeilds 217mm.
Simon TR4a
As Andy says, and others restate, rim width determines the tyre section you can use.
Wires look classic with a taller, narrower tyre, say a 185/70 or 185/75 on a 5 inch or 5.5 inch rim. Low profile, modern tyres on wires look "hotrod" not classic.
While they do look nice, personally I don't think wires look as good on a TR6 as the earlier cars, but thats a matter of personal taste.
Geo Hahn
gjh said:
...I just picked up a set of wire wheels & hubs for my 250. I am currently running 205/70/15's on steel wheels...
Have you considered keeping the Pirellis and switching back & forth? I run both wires and discs at various times. Get so much practice at R&R that I move around the garage like a NASCAR pit crew.
I guess I just like both looks and put enough miles on the tires that I still wear them out before they get too old. Someday (maybe next week) I'm going to show up on a club drive with wires on one side and discs on the other and see who notices.
Andrew Mace
Geo Hahn said:
Have you considered keeping the Pirellis and switching back & forth? I run both wires and discs at various times. Get so much practice at R&R that I move around the garage like a NASCAR pit crew....
Cool idea. But don't forget that you must use a spacer under the wire wheel hub in such a situation. It's that, or shorten the studs as emphasized time and time again in Triumph Service Bulletins. But once you shorten the studs for the wire wheel hubs, you really can't safely go back to steel wheels, hence the suggestion of a spacer (1/4" should do it).
G
gjh2007
Has anyone gone to the spacers to allow going back to steel, or alloys?
prb51
I use the spacers from Revington as they are made to fit the TR3 hub exactly although I know folks running the 6mm-1/4 in. generic with no prob. I have both sets of shod wheels.
Geo Hahn
I use the Generic version from a local Hot Rod wheel shop (thanks Andy for bringing this up, I should have noted spacers in my comment).
They may sell as 1/4" or as 6mm. I think one of the books (Williams or Piggot) mentions using a 9mm spacer but this would appear to be an unfortunate typo.
Have used them for years w/o a problem.
Doug_Henderson
I just bought a 1964 TR4. I'm a newbie to the TR4 world so I have a lot to learn.
The car has stock steel wheels and I want to put wire wheels on it. My question is whether there are any technical issues or clearance problems with using wider TR250 wheels on a TR4?
My car has 195/65R15 tires. From what I read in your posts, it seems these tires are too wide for 4.5" wheels -- they should be on wider wheels. But can I put wider wheels on my TR4 without problems?
Thanks for your help!
FYI, there is useful tire size conversion info in British Motoring Summer 2004 page 18 https://www.britishmotoring.net/
Brosky
Shannon,
I'm still wondering when you're gonna buy him a nice TR6 cap???
G
gjh2007
Will the spacers be an issue with the 205-70's?
LastDeadLast
Gary,
They might be.. I know mine are pretty close to the front fenders now, but then again, my rig is lowered an inch.
Brosky,
Where did you get a TR had to fit a kid? I've been looking for one.
MichaelG
Doug,
The 72 spoke wires should fit without modification on the TR4, and 195/65 15 tires are fine for this size wire wheel. I have this set-up on my 65Tr4A.
I don't have any experience with using spacers, but this would be the most convenient way to add the wire wheel adapter, and still have the flexibility to switch back to solid rims..as well as avoiding the task of either replacing or cutting the stock wheel studs to achieve the shorter length required for WW's. I my case I cut the studs because this was the path of least resistance at the time.
Cheers
Mike Godley
65 TR4A
Simon TR4a
Like Mike, I have a 1965 Tr4a, and have 2 sets of wires, the correct original ones with 165/15 and a 5.5 inch 72 spoke set
with 195/60/15 for general driving.
I did have 205/50 race tyres on the wider wheels at one time and had no clearance problems, though they are 2 inches smaller, which looked pretty strange but gave good acceleration!
Incidentally, i think the TR250 wires are 4.5 inch wide, same as the TR4, the steels may be 4 inch on the earlier cars.
simon.
T TR4/4A TR4A wire wheel tire size & powder coating? Triumph 18
H 15 x 6.70 Size Tire Ok for 100-6 Wire Wheel? Austin Healey 3
H BJ8 wire wheel and tire size Austin Healey 7
kch Tire size 6'' wire wheels\ Unipart oilfilter Austin Healey 7
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
M TR5/TR250 Compatible Modern Tire Size Triumph 5
F TR2/3/3A Spare Tire Size Triumph 11
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
D Series II E-Type tire size Jaguar 9
H BJ8 tire size Austin Healey 14
T TR5/TR250 TR-250 Tire Size Triumph 6
NutmegCT Tire size substitution Restoration & Tools 4
B experience with tire size changes? Other British Cars 2
B TR2/3/3A Tire Size Triumph 14
britlover proper tire size to replace 5.90-15? Austin Healey 16
S General TR Tire Size Triumph 18
Jim_Gruber Tire Size and Stock BE Wheels Spridgets 40
B T-Series MG TD metric tire size MG 5
B New VTO wheels ?? Tire Size for TR3 Racing 7
B VTO Wheels/Tire Size Triumph 13
O TR2/3/3A TR3 Wheel Swap and Tire Size Triumph 10
T TR2/3/3A TR3A Spare Tire Well & Tire Size Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
R TR2/3/3A TR3 Tire brands and size Triumph 5
K TR3 Tire Size for Shelby 500 Alloy Racing Wheels? Racing 0
K TR2/3/3A Tire size for 5.5x15 alloy racing wheels? TR3 Triumph 8
60TR3A What Size Tire is Ideal for a 15" X 5.5" Wheel? Triumph 29
tmc Tire size for the spare Triumph 10
V Tire size consensus Triumph 4
ekamm TR2/3/3A 3a steel wheel tire size? Triumph 14
J Tire size Spridgets 8
L What size tire will fit... Austin Healey 17
toysrrus RE: Tire Size Suggestions Wanted: Triumph 5
A bugeye tire size Spridgets 5
longbridgehealey Bugeye tire size Spridgets 2
MTribe TR6 TR6 tire size photos? Triumph 30
tomshobby tire size? Spridgets 11
D Tire size for 73 midget Spridgets 2
T Largest tire size I can put on my 89 xj40 Jaguar 1
6 Tire size conversion Triumph 0
htchevyii MGB need tire size recommendations for 77 MGB MG 6
E BE Tire Size Spridgets 20
L Street Tire size for 60 spoke wheels Austin Healey 15
Steve P. 5" aftermarket rims, what tire size needed??? Spridgets 3
N TR6 Opinions on 205-70R15 tire size for TR6 Triumph 11
I Bugeye tire size Spridgets 3
longbridgehealey Tire size Spridgets 12
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
Morris Stock tire size Spridgets 11
