RAndal
What does vacuum specs 7-14-10 mean?,listed for tr3a.
I forgot about starting rpm advance.
What is vacuum advance+ centrifugal,to equal total?
From the chart it looks like 8.75 at 700,low idle, 14 degrees(total I guess) at 2700and 1.75 at 500.Not sure if idle would go that low to check.
I guess after setting at 8.8 with light you could then check static and see what the difference is.
Never hand started my old tr3,but too much advance kick back can break your leg on an old motorcycle.
I agree with the road test method but feel that may be fine tuning,after initial tuning.
I usually like to set timing by book,then it's one variable elimenated when adjusting carbs.Then back to fine tune ign. timing ,then back to carbs.
Thanks for the great info,I'm here to learn.
Tom
Tom
