there's gas in my oil
JMACK
Hi everyone, I was running my "76 B the other night in the garage and noticed a slight drop in oil pressure, from about 80 to 50 pounds at idle. I shut the motor down and checked the oil level, when I removed the dip stick I could smell a strong odor of gas. I wasn't sure what this meant and thought it best to change the oil, well, when I pulled the drain plug I was quite suprised that instead of black old oil I saw, brownish thin liquid, more than six qrts worth. I spoke to a friend who said my needle valve was bad and excess fuel was being dumped into the crank case, is he correct? How should I corredt this? What precaustions do I need to take before I restart my engine? Thanks MACK
piman
Hello Jmack,
does your 'B' have a mechanical fuel pump, if so it could be that the diaphragm is leaking fuel directly into the crankcase.
By the way, that oil pressure sounds far too high.
Normal running pressure should be about 50 psi above 2,000 rpm.
Alec
J
JMACK
Alec, Thanks for getting back so quick. The fuel pump is electric, I've noticed the contacts clicking when I turn the key on, is correct? Someone told me, if this happens every time I turn the key on this could be an indication of fuel leaking "somewhere" what do you think? JMACK
aeronca65t
You should definitely fix thais problem ASAP. Gas in the engine oil can cause rapid wear of your internal engine parts.
The most likely source of a problem like this is a sticking float valve in the carb. I'm surprised that you haven't mentioned that the car is creating a lot of black smoke or running extremley rough (due to an overly rich mixture).
At any rate, carb repair of this sort isn't that expensive so you should get it done straight away.
You're sure it's gas, right? (and not anti-freeze from a head gasket problem)
A
aerog
I'm not sure how the fuel pump can be suspect - it's mounted at the fuel tank and pumps forward. A certain amount of "clicking" is normal if the car's been sitting awhile - but if you switch the ignition on and it keeps clacking away you might have a leak.
If you have a bad needle/float valve and it's letting fuel pour out of the carb (which, if your pump constantly runs might be a good clue). I can see a cylinder possibly loading up and diluting the oil, but two quarts seems like an awful lot.
Normal idling oil pressure is 10-25lb, running pressure 50-80lb by the way.*
* From the official MGB shop manuals
[ 04-16-2004: Message edited by: aerog ]</p>
G
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by JMACK:
Hi everyone, I was running my "76 B the other night in the garage and noticed a slight drop in oil pressure, from about 80 to 50 pounds at idle. I shut the motor down and checked the oil level, when I removed the dip stick I could smell a strong odor of gas. I wasn't sure what this meant and thought it best to change the oil, well, when I pulled the drain plug I was quite suprised that instead of black old oil I saw, brownish thin liquid, more than six qrts worth. I spoke to a friend who said my needle valve was bad and excess fuel was being dumped into the crank case, is he correct? How should I corredt this? What precaustions do I need to take before I restart my engine? Thanks MACK<hr></blockquote>
I find it very hard to believe that all that gas is getting into your oil from the carbs and the car still running. 6 quarts is an awful lot of gas. Are you sure its gas? Is the car parked ever anywhere where someone could tamper with it and vandalize it by puting the gas in the oil. As I grew up there were some kids that would do such a thing.
The fuel pump will click a couple of clicks when you first turn the key but should stop. If it keeps running, there is a leak somewhere.
Maybe there is water in the oil and you have two problems. A gas leak thus the strong odor and water in the oil indicating a head gaskit bad.
I think we need more info on how the engine is running. Is it running fine, is it smoking (black smoke out the exhaust, Are bubbles coming up in the radiator at idle, is there oil in the water, how is the compression, to just name a few.
Bob
JTB
Have a 69, never re-built engine that runs at 40-50 lbs at idle and 70-80 lbs at speed. From what I can tell there is a fairly wide acceptable operating range per Piman's post. Whatever it is absolutely...the change is troubling, naturally, and must be due to the oil thinning. Wish I could add something intelligent about the next step. Shouldn't the carb overflow tubes take excess off? I am not very knowledgeable about carbs (yet...heh,heh). It does seem like a heck of a lot in that period of time.
J
JMACK
Hi everyone, thanks for all the help, here are some answers to the questions asked. No oil in the antifreeze, it's a fine shade of green, the car runs great(in the garage that is, I am not "on the road yet"}, no black smoke, very slight hint of white, blue type smoke, but very "fumey" exhaust smelling, no chance of tampering, the car is locked in my garage and compression is about 90-92lbs on all four, looked at the plugs while doing the comp. test all the plugs seem to have some dry black carbon, I'm using Autolite 63's. Thanks again for all the help. J MACK
Jim 67B
black plugs mean you are running rich. The compression looks way to low. Check the compression both dry and wet and see if there is a difference.
J
JMACK
Jim 67B, Thanks for answering, I went back out and rechecked the compression, I forgot to use the adapter with the O rings for a tight seal, I only did a dry test and the comp pressure was 122 on all four, I hope that sounds better!! Next you said I'm running rich, how do I adjust? I have the SU tool for that adjustment, do I turn clockwise or counter-clockwise? Or something else? Thanks, John
aeronca65t
Your compression sounds OK. The adjustment tool you have (I guess) is the wrench that turns the main jet (under the carb). Your main jet can be turned CW (looking up from under the carb) to make it leaner (less rich). Truthfully, the car should be fully warmed up...if you're not really driving the car at this point, wait until you have a chance to drive it for a bit before doing this.
I would change the oil again and keep and eye on the level. You could also tap on the float chamber (while the engine is running) with a small wrench...this can "unstick" a stuck-float needle.
You mentioned the SU tool, so I'm assuming your car has SU carbs (normally that year doesn't). One of the best Brit carb sites I've seen is here:
https://www.teglerizer.com/sucarbs/techtip6.htm
[ 04-16-2004: Message edited by: aeronca65t ]</p>
GTsRFine
I think your floats are stuck/sticking open. The float bowl overflows may not have been correctly hooked up when the SUs were back-fitted to your 76 MG.
Is your fuel pump the stock SU pump? If not, it may be pumping at too high of a pressure which would overpower the float bowl needles.
GTsRFine
Let me hurry to Add:
Don't run the engine until you get this fixed!!!
You will destroy the bearings , followed shortly by the rings.
G
I've had some more thoughts on this problem. Isn't the 76 a single Zenith carb? I have dual HIF4's and the hose from the oil separater splits and goes to both carbs. What if on yours the hose from there got put on the bowl overflow by mistake and the needles are leaking as said earlier. That would dump raw gas down into the oil through the oil separater. On mine the connectors are very much different in size so that problem would be minimized but I don't know about the Zenith.
Other than that I don't know maybe someone more familiar with the Zenith Stromberg would know.
I agree it would not be wise to run the engine with that diluted mixture in the oil until this is resolved.
Also there is a section on tuning the Zenith-Stromberg on page 27 in the Moss catalog.
Bob
[ 04-17-2004: Message edited by: mrbassman ]</p>
GTsRFine
Mea Culpa on not reading the post carefully. I must have mixed it up with another post about swapped ZS to SU.
I don't know much about ZS carbs but, in general, leaky float needles can dilute engine oil.
P TR6 Gas in oil? Triumph 12
healeyboz gas in oil Spridgets 1
C Gas & Oil Triumph 15
Got_All_4 YIPS Took out 4&1/2 gal oil & gas from crank case Triumph 18
R6MGS Gas, Tires, and Oil Other Cars 12
7 Gas in oil conundrum *long post* MG 4
Celtic 77 MGB LeMans Gas filler MG 10
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
B gas leak underneath the carburetor Restoration & Tools 2
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
LAW75 Concours: Original Gas Hose Austin Healey 12
LAW75 Gas Odor Elimination Austin Healey 3
B TR4/4A GAS TANK FELT Triumph 14
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
edkap2002 TR6 gas smell Triumph 8
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
B Damaged threads in the gas tank Austin Healey 7
BierRunner TR6 TR6 Gas Pedal Triumph 4
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR4/4A Gas Tank color? Triumph 4
B BE vs. Later Model Gas tanks Spridgets 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D What's inside the gas tank?? Spridgets 13
C TR2/3/3A Gas Line Triumph 11
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S TR2/3/3A TR3 gas filler cap Triumph 1
J TR2/3/3A TR3A gas tank repair Triumph 7
longbridgehealey Fuel pump racing, no gas Austin Healey 26
Rut MGB Running out of gas symptoms MG 21
T TR2/3/3A TR3A Gas Cap Triumph 15
D Gas Pedal Pad Jaguar 7
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
T magnets and gas tanks, and other applications Austin Healey 3
