Hi everyone, I posted this in another MG forum, but I wanted to get feedback from members here as well...
I've been diligently doing bodywork on the '74 MGB GT I bought this fall. Yesterday I was getting tired of drilling and chiseling, so I decided to concentrate on mechanical things, which I prefer over metal work. I pulled off and sold the Weber DGV that came with the car. When I took the carb off this fall, the engine only ran on three cylinders. This was fine, I knew it did it and I figured once the bodywork was done I'd go through the ignition system and rebuild a pair of HIF4 carbs and get the engine sorted out. The three cylinders that did fire did so smoothly, although I have never checked compression on the cylinders (need to remember to get my dad's compression gauge next time I go home from college).
Anyway, last evening I went to remove the old Uniparts oil filter and I drained the engine of oil. I noticed that it was flowing very fast for such cold temperatures, and in fact seemed very 'liquid'. I let some splash onto my fingers and the 'oil' was like water, no thickness or viscosity, and smelled like gasoline. When I bought the car, it had been sitting for months excpet for the occasional startup when the previous owner was showing the car to prospective buyers. Six months ago he said he'd been using it regularly, but that the engine had a miss (I think it was probably running on 3 cylinders then too). My theory is that there has been excessive borewash and it's been contaminating the oil. Is this plausible? or should I be searching for other possible culprits...also, the car has been run with very non-viscous oil for God knows how long, probably not too good for the bottom end. Oh well, thoughts and opinions as to how I should approach this?
