TR2/3/3A the door locks
sp53
Well on the door locks, the 2 that I would like to fix will not come out. The one in the picture is an extra one I had, and it popped right out after the pin was removed and struck on a block of wood. Anyone have experience with locks that will not come out. I believe they are oxidized in and will not budge. I tried banging them against some wood for 10 minutes, but no luck.
steve
mrv8q
A good soaking in PB Blaster, perhaps?
S
sp53
Well tried all the soaking stuff, but I will try again. The keys will not go in on both door locks. I tried using a pick and pushing from the back in that little hole were the pin goes but cannot get any good leverage. I am thinking about making a custom pick that I force from the back a little better. Another idea I had was to make one of those rust hydro remover deals with a battery charger to see if I can get the oxidation to drop off, but that might be too much work for something this small and like this. Maybe dropping them from an airplane would work, but then I might not be able to find them. Another thought was to pack them with string and see if I could push them out that way from the back that way. I saw locksmith do something like that once. I tried that a little but everything is so small and very stuck.
charleyf
If the key will not go into the lock is there possibly a broken key in there?
It would be most helpful if you can get the key hole either empty or with the correct key in it.
To clean out the key hole try using a drill smaller than the width of the key. Use it by hand first and use it on the bottom or flat portion of where the key would be. I am thinking that if there is something inside the key hole it may be lifting up the inserts and holding the tumbler cylinder in. That is my best guess!
Charley
LAW75 BJ8 Door Locks Austin Healey 2
R Jaguar XJ6 Door Locks Jaguar 8
M MGB Early MGB door locks MG 7
M Adjustment of XJ6 Door Locks with Keikert Solenoid Jaguar 5
G Power door locks! Spridgets 23
vping Door locks - How do they come off? MG 6
J TR6 how do you remove the door key locks on a tr6? Triumph 2
R6MGS stubborn door locks MG 5
Webb Sledge Door Locks Triumph 5
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 6
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
Cappy Occasional Door Malfunction Austin Healey 1
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Door Seal Austin Healey 5
