Technical Questions
  • Thread starter Deleted member 8566
  • Start date
Deleted member 8566
I'm having minor issues I was hoping someone could shed some light on. Under the dash on the drivers side, there are white wires that go into the plunger, on one side there are two white wires and on the other there are one, at some point, the previous owner cut and spliced the single wire to connect to the two wires and taped them back together, now when driving the wires get really hot to the point you can smell the rubber sheath burning. I can not find any kind of short or anything, are there any ideas to this, if I unhook the plunger the fuel pump stops working.
Platinum
Check and clean the ground points at your fuel pump... The wires can get warm but shouldn't be hot. It would seem you have resistance somewhere in the circuit of the pump.
Kimberly
Take a look at the wiring diagram for the car. The diagram shows how one of the terminals on the inertia switch is being used as a splice.
Wiring diagrams are available at https://www.advanceautowire.com click on stock schematics.
There are three main reasons I have found for hot wires; a short, circuit overload (too many amps, too high a power draw), and high resistance caused by faulty connections and/or corrosion.
Make sure all terminals in the circuit are clean and secure.
gsalt57tr3 Some technical questions MG 10
Webb Sledge Technical questions Triumph 9
KVH General Tech More Technical Questions—TR4 Triumph 5
X Technical specifications including the maximum technical weight TVR 8
jdubois Wanted Old BMH Original Technical Publications CDs Triumph Classifieds 0
M TR2/3/3A Technical Assistance Needed - TR3B Carb Adjustment Triumph 5
Willie_P TR4/4A Tr4 bonnet latch bracket [highly technical] help! Triumph 6
J Clutch Woes - Need some technical assistance Spridgets 5
MikeAH100M Original Technical Publications from AH Spares Austin Healey 1
Moseso Technical Report: Bronze Spring Bushes Triumph 26
Willie_P TR4/4A tr4 tie rod end/ball joint - technical question Triumph 2
Westfield_XI A good source for technical info Spridgets 2
QuickSilver Technical: Converting From Wire Wheel To Standard MG 6
Don_Racine A technical consideration Austin Healey 3
JodyFKerr Europa Technical and Parts information Lotus 6
jclay Wedge Wedge Technical Site Triumph 5
angelfj1 Bolts - technical resource Restoration & Tools 0
J TECHNICAL INFO IN PDF Jaguar 9
W Ordered Technical CD Triumph 6
jlaird Kina technical question Spridgets 6
tony barnhill Technical Question - Steering Lock-to-Lock MG 9
PeterK Buckeye Triumph technical info Triumph 6
jsneddon SU and Stromberg Technical Documents Triumph 0
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K General MG 1968 Midget Questions MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W General Tech 2500S starter motor and fuse box questions Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
P MGB 1980 MGB carb and oil questions MG 3
C My 2500M progress/questions thread TVR 5
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
B TR4/4A Dumb Bumper questions Triumph 4
B Two questions about Bugeye floor panel weld drilling Spridgets 15
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
R TR6 Questions on emission tank-to-canister pipe Triumph 0
AngliaGT MGB-GT Couple of Dumb Questions - '67 GT MG 11
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
D TR2/3/3A More Fuel pump questions. Triumph 10
K TR2/3/3A Hard start questions.... Triumph 4
F TR2/3/3A back half to chassis questions Triumph 105
D Carpet Questions Austin Healey 2
J TR6 73 TR6 Static Timing Questions Triumph 6
glemon Spitfire Spitfire Questions Triumph 7
B TR4/4A General exhaust questions Triumph 17
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
Pythias Springs and ride height... Questions. Spridgets 2
L TR2/3/3A Engine removal questions Triumph 8
I Brake rod questions Spridgets 7
