Tech question
capitalcitycars
Hello all. I purchased a midget for restoration in Sept 2005 and I ran into a little problem. I have a 1976 MG Midget with the 1500 engine with manual choke. During the current restoration, the non-functioning cei distibutor was replaced with a Mallory dual point distributor, carb upgraded to a Weber DGV, ignition celenoid replaced, starter replaced, alternator replaced. The car started instantly but refused to shut off even with the battery turned off and key removed from ignition. I replaced the iginition assembly but the problem is still occurring and the red light on dash stays lit. Also, I have no tach. Any suggestions would be most helpful. You can see the car at my website @ www.freewebs.com/lansingmidget.
First, I recommend posting this question in the "Spridgets" forum also, because that particular forum is dedicated to Sprites and Midgets. So, there's a chance of someone there with more knowledge of your car to reply than in this forum.
I'll try and help spur the trouble shooting process though. Have you checked your ignition switch? Is is cutting power to the ignition coil? Is the ignition coil connected properly? If it's connected improperly it may be possible that it's drawing power directly from the alternator. If I'm not mistaken the tach gets its reading from the coil on some cars, though I must admit I don't know if that's the case in your car. However, if the tach isn't working and the ignition coil never gets interrupted then I'd probably start looking there.
I'm sure someone more knowledgeable in this area of trouble shooting will be along shortly...
best of luck to ya
never mind my first statement.... I see you've already done that.. /ubbthreads/images/graemlins/smile.gif
Replace your Duracell battery with a non-bunny battery or double check the wiring. /ubbthreads/images/graemlins/rolleyes.gif
"B"s are the only ones with Bunnies in them. Midgits have full grow squirrels.
mark
I shot the bunny already and put in a few hamsters. If I knew what other wiring to check, i wouldn't be posting! /ubbthreads/images/graemlins/smile.gif
I seem to recall that some failure mode of the alternator would feed power back through the ignition switch. I think that "back in the day" JRT had a service bulletin for this that placed a diode in the alternator harness. It has been 20 plus years since I encountered this problem, so my defective memory might be playing tricks. I would think that if you ran the car with the Alt. disconnected, and the car stopped normally, at least you would have a direction to go in. If not, I would carefully recheck the ignition wiring.
What alternator/voltage regulator combo are you using & did you replace the IGN switch with an OEM type. Try pulling your IGN warning light bulb.
Get the correct wiring diagram for that particular car and trace the circuits. I think that you have just switched a wire. If you don't find it that way call Mallory and tell them what is going on and they will walk you through the fix. Jack
N Supercharger tech question??? Spridgets 8
N Tech question??? Spridgets 12
G A tech question Triumph 13
C Newbie Tech Question- Weber Carb Spridgets 10
C Tech Question Spridgets 13
R tech question to those that might know. MG 3
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
A Spitfire BMCNE -Tech Session Custom Wiring Harness Creation -Links to Album Triumph 2
A Spitfire BMCNE Tech Session - Photo Album - Triumph 0
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
M Some Tech Advice Needed for Horn Brush on 59 Bugeye Spridgets 10
paul9999 Old tech diesel - empty Other British Cars 3
glemon Tech Tip, Wonky Switches Restoration & Tools 3
DNK General TR Tech Auto Co. UK Triumph 0
Rut Tech school bodywork Spridgets 8
Brosky New "Trafficator" now available from Classic Tech Triumph 16
PAUL161 The Shade Tree Tech by John Weimer [Thanks John] MG 0
B Healey 3000 tech Q Austin Healey 12
JPSmit tech Latest - spridget 50th [and the day] Spridgets 13
Gundy Incredible tech session pics Spridgets 16
Trevor Jessie Eezi-Bleed Tech tip Spridgets 1
Superwrench tech info FORUM Navigation Questions 1
M Tech help on diffential swap Spridgets 6
S TR 4 and 6 racers--tech help needed Triumph 7
glemon Thanks Buckeye Triumphs Tech Help Triumph 2
PAUL161 Tech Tips Via the Motorhead web site. Helpfull! MG 0
AngliaGT Don't You Just Love Hi-Tech? Other Cars 19
YankeeTR Bumper Replating Tech....A Must See Post !!! Triumph 2
H TR6 TR6 Gas Cap Spring Tech Tip Triumph 4
jaybird The 'bird's Tech Tip #17 MG 42
MGA Steve MGA NAMGAR Tech Notes Available MG 1
D Tech Manuals Spridgets 9
S Tech Manuals... MG 2
G Buckeye Triumphs Tech Tips Triumph 19
W windshield wiper tech on 74 XJ6L Jaguar 1
Patton Burning up rotors - plus tech tip to get home!!! Austin Healey 16
G Tech Session at Tom's Place MG 4
J Lotus Elise can be had with a sequential shifter and the new turbo tech supercharger Lotus 6
M MGB Disributor clamp question MG 1
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
