tech question to those that might know.
richardJr
I have a alternator issue and was wondering if I could
"make work" a 68 mgb alternator in a 71mgb gt. The problem being simply is they are two different breed of cats...one with and one without an internal voltage regulator. I was thinking maybe...(praying to the lucas lord) ..could I just swap the brush box and get the connections correct (5 terminal type connector) plus add the internal voltage regulator along with changing the plastic case so I can actually plug it in? My real question is about the rectifier...are they the same being they are both a 34 amp system? I did check part numbers for each rectifier and they are indeed different. Not that I am a cheap person...just that this alternator is starring me in the face and I look at it and see all the new windings and internals...like to use it if I could. For those that want to give me a hand...
In 1968 alternator Part 23548 (34amp) became a standard fitment with an external voltage regulator. In 1969 Part 23716 (34amp) was introduced incorporating an internal voltage regulator with a 5 terminal type connector. In 1972-73 saw the introduction of a newer style alternator Part 23804 & 23748 (both 34 amp) with a simplified 3 terminal connector plug Part 54960402, this continued thru mid- 1974. At this time yet another style of alternator was introduced Part 23756 (A1816 43 amp) with a different connector plug assembly. This alternator fitment continued into 1978 thru ID number 471000. From ID number 471001, yet another alternator was introduced Part 23737 (A1812 43 amp) using Part 54960402 style connector plug.
And of course I need the 23716 but have the 23548. If it can't be done...I have one for sale! It would fit a 68 mgb very well.
Thank you all who reads...and I wish upon you all a very happy day.
Dave Russell
Yoda - R.I.P
And a very happy day to you also. I have no idea about your alternator question, but surely someone here knows. If no one jumps in, I will try to help.
BCruzn
Richard, Hi, where did you get your present new alt.? I've just replaced mine, and come to find out there where two different alts. put on 70 B's that year, all I did was to take my old alt. to O'Rielys, said I need one of these and he brought out a rebuilt Lucas, an exact match. I also spoke with Bob Ford at Brit-Tek. He stated that altho' a number of alts. where put on B's in 70', if they have the five connections, go for it. You can also refit your B with a Delco three connection alt. Go to MG enthusiast for details (in the archives). LOL /ubbthreads/images/graemlins/hammer.gif
N Supercharger tech question??? Spridgets 8
N Tech question??? Spridgets 12
G A tech question Triumph 13
C Newbie Tech Question- Weber Carb Spridgets 10
C Tech Question Spridgets 13
C Tech question MG 10
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
A Spitfire BMCNE -Tech Session Custom Wiring Harness Creation -Links to Album Triumph 2
A Spitfire BMCNE Tech Session - Photo Album - Triumph 0
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
M Some Tech Advice Needed for Horn Brush on 59 Bugeye Spridgets 10
paul9999 Old tech diesel - empty Other British Cars 3
glemon Tech Tip, Wonky Switches Restoration & Tools 3
DNK General TR Tech Auto Co. UK Triumph 0
Rut Tech school bodywork Spridgets 8
Brosky New "Trafficator" now available from Classic Tech Triumph 16
PAUL161 The Shade Tree Tech by John Weimer [Thanks John] MG 0
B Healey 3000 tech Q Austin Healey 12
JPSmit tech Latest - spridget 50th [and the day] Spridgets 13
Gundy Incredible tech session pics Spridgets 16
Trevor Jessie Eezi-Bleed Tech tip Spridgets 1
Superwrench tech info FORUM Navigation Questions 1
M Tech help on diffential swap Spridgets 6
S TR 4 and 6 racers--tech help needed Triumph 7
glemon Thanks Buckeye Triumphs Tech Help Triumph 2
PAUL161 Tech Tips Via the Motorhead web site. Helpfull! MG 0
AngliaGT Don't You Just Love Hi-Tech? Other Cars 19
YankeeTR Bumper Replating Tech....A Must See Post !!! Triumph 2
H TR6 TR6 Gas Cap Spring Tech Tip Triumph 4
jaybird The 'bird's Tech Tip #17 MG 42
MGA Steve MGA NAMGAR Tech Notes Available MG 1
D Tech Manuals Spridgets 9
S Tech Manuals... MG 2
G Buckeye Triumphs Tech Tips Triumph 19
W windshield wiper tech on 74 XJ6L Jaguar 1
Patton Burning up rotors - plus tech tip to get home!!! Austin Healey 16
G Tech Session at Tom's Place MG 4
J Lotus Elise can be had with a sequential shifter and the new turbo tech supercharger Lotus 6
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
