Old tech diesel - empty
paul9999
Hello All
just discovered my Austin FX4 (1965 London black cab) is completely empty (no diesel in the tank)
This all due to a faulty fuel gauge and fuel line leak.
My question - how would I restart it? I imagine it is not just a case of filling up and cranking for 10 minutes - do I have to prime the pump? Fill the fuel filter? something else?
Appreciate your help
regards
Paul
TomMull
You have to completely bleed the fuel system. If you have a lever on the fuel supply pump, you can use that but I usually just crank the engine. As I recall, there is a hex head bleeder on the fuel filter. Bleed that first until you have no bubbles. Then there is a bleeder on the pump. I think that is also a hex. That needs to be free of bubbles too. Finally, not in the manual, but what I do is crank the fuel line nut on each of the injectors while cranking the engine. Tighten the nuts when you see a bit of a leak. If all fails, repeat. These can be quite reluctant but they will start eventually.
Tom
paul9999
paul9999
Tom,
Surprisingly easy - just bled the system and she started straight up - appreciate the pointers
cheers
Paul
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
K TR2/3/3A Old school penetrating oil? Triumph 24
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
S TR2/3/3A old 4 bolt axle differential. Triumph 11
R Old History - List of USA TVR Authorized Dealers TVR 10
Popeye General TR Old robbins top in box Triumph 7
dougie Pistons - Old vs New Austin Healey 12
B Help for Old Men Restoration & Tools 15
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
roscoe New / old hard top Austin Healey 16
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Removing Old Radio Austin Healey 4
Bob Claffie New old car Other Cars 7
Mark Bailey Old tire rule? Restoration & Tools 5
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
T TR2/3/3A Question on old radio from my TR3 Triumph 9
DrEntropy Looking thru old pix Other Cars 8
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
B Dodge Chrysler Cool Vanilla = Old English White? Spridgets 7
R How old is "dead" FORUM Navigation Questions 5
D General Tech Old gasoline disposal Triumph 17
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
tinman58 General Tech Why I love old cars Triumph 1
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
B TR6 New [Old] Member Triumph 2
M Old English White Paint Code for early BE Spridgets 1
E Trying to ID some old classic car gauges Restoration & Tools 2
Zitch For Sale TR4 - old door cards Triumph Classifieds 0
AngliaGT Cool Old Truck + Spotted 1
D TR2/3/3A Recondition old wire wheels or buy new? Triumph 10
jfarris "Old Yeller II" Spotted 3
anarchy99 Help with new [old] Sprite hardtop Spridgets 17
CessnaTPA New Tires or Keep Old Ones Austin Healey 36
AngliaGT My Old Ford Consul Capri Other Cars 0
Answerman Restoration of OLD [pre WWII style] leather seats Restoration & Tools 5
jdubois Wanted Old BMH Original Technical Publications CDs Triumph Classifieds 0
doc50 New old member. Spridgets 43
doc50 New Old Member...sort of. Spridgets 7
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
S TR2/3/3A On those old original coils Triumph 2
D never throw old parts away.... Austin Healey 7
simon1966 Eclipse Day Photos, back to her old color! Austin Healey 2
JimLaney Liquids for 50 + year old Sprite Spridgets 5
