Morris
I have an RVC tach (the one that came in my '79) that is non-functioning with my EDIS set up. It was working with my previous electronic ignition system. I have tried several suggestions I have read on other forums, but nothing has worked so far. So far I have tried: connecting directly to the tach out line on the edis (many people report success with this method and an RVC tach); connecting to a circuit made of two diodes and a zener diode that connect to each coil bank ground; and a 680 ohm pull up resistor between the 12v in on the tach and the tach signal from the EDIS. The last one kind of works... it reads at idle but drops to 0 when I rev.
Any suggestions, thoughts, RVC wisdom or general electronics wisdom would be much appreciated.
