Wedge SU Carb and Intake acuqisition for Federal TR7
Hegg
Does anyone have a good lead on places that can sell a (used) SU + intake setup for a TR7? I'm planning on moving my Federal TR7 to SU carbs and just need a good source.
Thanks!
MDCanaday
The carbs are a bolt up for this manifold just pick up a set on ebay or a swap meet. I know a friend who likes his conversion very well.
MD(mad dog)
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
P For Sale Weber carb/intake, header Spridgets Classified 2
bugedd Carb/intake question Spridgets 6
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
Patrick67BJ8 BJ8 - Intake Manifold, carb, gaskets sequence - Info needed Austin Healey 2
Patrick67BJ8 Copper Drain Lines for BJ8 Carb/Intake Manifold Austin Healey 30
RickB H1 carb set with intake - any value? Spridgets 2
D Triple Carb Intake Triumph 8
6 T-Series MGTC / MGTD Period Correct Carb/Intake Systems MG 8
10musketeer Carb intake gaskets Spridgets 17
Lin intake manifold to carb studs Austin Healey 11
K Intake Manifold for Tri-carb on Ebay Austin Healey 0
coldplugs T-Series Help! Carb, intake, etc.. Car wont start MG 6
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
