Re: Steering not right - follow-up steering worm damages
Hi All,
Not sure if this should be a new thread but I chose to add it here since it is the same project, and connected.
So, since I had identified the problem with the rocker shaft, I went ahead and put the steering together for the final time (all the earlier part of the thread was with the old tie rod ends and outer links because it was coming apart/back together so much I wanted to save the new parts for a final assembly so everything would have nice paint and such).
Once I had the springs in and all the rods connected and everything ready to drive (car is not but steering was), I set about trying to dial-in the steering box free play. As other threads here have discussed, there can be a lot of trial and error getting the things as tight as possible without binding.
I fully expect to do more of that when I finally get it running but I started noticing an odd thing - as I turned it to the right, past the 'tight spot there was a bit of variable resistance to the turn (rumbly) but going the other direction, turning to the left past the tight spot, it was as smooth as ever. I kept turning it back & forth and adjusting but no matter how much I loosened the set screw the same slightly rumbly feel turning right and smooth turning left. So I finally decided something wasn't right and took the box out of the car to check it out.
All the ball bearings and races are still perfect and I was feeling the worm when I noticed a slight deviation near the center of the travel. So subtle I had not noticed it when I had the box apart to put in new balls and races a while ago.
In the accident the pitman arm was bent to the left and the pitman shaft was twisted to the left - I don't remember any particular strain in my hands from the steering wheel but there must have been a lot to twist the shaft and bend the arm and that all translated to the peg so obviously a great load on the worm. This load hammered a deflection into the side of the worm groove and cracked the worm - I couldn't see the crack until I rubbed it with a Sharpie and wiped off the surface (cheap home-brew die-penetrant test
). I had replaced the pitman shaft and the peg and needle bearings but missed the damage to the worm (BTW, there was no sign if damage to the peg, I just had a new one so I used it).
At least this explains the weird feel when turning the steering wheel.
Here are pics of the worm - it was hard to get pictures to show what I'm describing - took it outside into bright sunlight and hope you can see the damage, I put
blue sharpie marks on either side of the damaged area and crack
Obviously a new worm is called for. Even though I wish I was done with the steering, I'm real glad I tore it apart again and found the problem. At least I know I really need to spent the money on this one.....
I doubt it could have resulted in any sudden catastrophic failure but you never know and steering
is kinda important.
I decided to post this as a follow-up in case anyone is rebuilding a wrecked or accident damaged car, you may want to examine the worm closely.... I though that, except for the ball bearing races, these worms were pretty indestructible - now I think not!
Dave
