red57
OK, next installment. Today I tried two other used rocker shafts with no real change. There are minor differences in the various combinations of shafts and arms but nothing near the change I need.
A couple of pics - these are hard to measure so I tried to take exactly the same pic of 2 shafts & arms - first is new shaft and 2nd is old shaft.
So, not sure what I'm going to do but it seems possible that I might be able to carefully grind away a second spline adjacent to the ones they removed and achieve a 10* rotation of the arm in relation to the shaft??? Otherwise I don't know what other options I have since no individual parts/components seem to be wrong but the assembly just isn't right. :confusion: I even spent some time going back and checking the basics - the shock towers and the steering box & idler mounts are in the right place and the box as well as the suspension bits all fit like they are supposed to, the frame is straight and true.....
Thoughts?
Dave
I started looking more closely at the splines on the replacement shaft and was surprised at how crudely the removed splines were done. Here are comparison pics, first the old shaft and then the new one.
Marginal workmanship and it almost looks like they missed the one they wanted to remove - got part of two. That got me curious so I counted the spline teeth on the shaft and there are 36 teeth - with one removed every 90* to 'key' the pitman arm so it can't be installed wrong. So 36 teeth equals 10* per tooth and I can say for sure that none of my shafts or arms are one full tooth different.
So I tried to check just how much change I needed to get the rocker centered in the box and the arms pointed the right direction (centered). To do that I placed the head of my protractor against the shock tower and sighted on the pitman arm. The first shot is with the rocker centered and the 2nd is with the arms centered evenly and, interestingly enough the difference is about 10*. Marginal workmanship and it almost looks like they missed the one they wanted to remove - got part of two. That got me curious so I counted the spline teeth on the shaft and there are 36 teeth - with one removed every 90* to 'key' the pitman arm so it can't be installed wrong. So 36 teeth equals 10* per tooth and I can say for sure that none of my shafts or arms are one full tooth different.
Thoughts?
Dave
