Spark Plug Gap
dougsmarkIII
My 66 BJ8 has the Pertronics distributor module installed and the Pertronics Flame Thrower Ignition coil. Should the spark plug gap be changed to take advantage of this combination and what gap?
Believe the plug gap is set at .025 at this time, but am getting ready to change plugs tonight. I'll check back later for replies after the old ones are out.
Doug
wangdango
I installed an Allison ignition system (which I think is Crane now), way back in '93 and set the points to .060
The car start up instantly, in any temperature. I think this produces so much spark you could almost cut off the protruberance (thing you move/adjust when you gap a plug).
My car is a '67 BJ8 btw.....
dougsmarkIII
If your plug gaps are set at .060 then you must have a CD ignition system. Believe the Pertronics module just replace points and the Flame Thrower is a little hotter than stock.
I will probably increase the gap .005 to .030 on my system.
Doug
elrey
The adjustable bent strap off the end of the threaded portion of the spark plug is known as the Earth, Side, or Ground electrode.
wangdango
Its been so long I forget what its called. There is a small "box" about 1/2 the size of a paperback book that is part of the system. Pretty sure this type of system is the one Moss still sells now made by Crane... All I know is this has been a great and worthwhile upgrade!
RAC68
Wangdango,
The unit you are describing is a Capacitive Discharge Allison/Crane system. It is an optically triggered system that can handle the types of conditions produced when setting the plugs at 60 thousands. I have had the Crane version installed after my original Allison failed in about ’94 but have never tried setting the plug gap past 35 thousands.
I have a Pertronix installed in my Triumph and like it for its stability and ability to be hidden. I don’t believe it is as robust as the Crane and be able to handle extended plug gaps of the magnitude you are using.
All the best,
Ray (64BJ8P1)
Cottontop
I have run a Pertronix Ignitor (IN the distributor) module in my 1966 Mustang GT Fastback and also in my Ford 302 V8 Healey.
The Pertronix Ignitor module is NO MORE than a points replacement. It is a simple magnetic ON-OFF switch. It does nothing to enhance or change the spark.
When powered by a full 12 VDC, the Pertronix Flamethrower coil should dispense about 40 KV which will allow the plug gaps to be opened up.
I would check with Pertronix for their advice, but with a similar Mallory coil, I run my plug gaps at .045".
Tim
AUSMHLY
Doug
I'm negative ground, pertronix, lucas sports coil.
Champion plugs are gapped at .035
Lin
Roger, I am happy to learn that we use the same oil filter and have the same plug gap, but I don't have one of those frayed wires in my distributor: very un-Roger-like!
Just kidding Roger!
Lin
John Turney
Roger,
I, too, can't believe you have a frayed wire on your car! I also wonder about those wear marks on the top of your rotor; there should only be the one point where the carbon center post presses on the rotor. It looks like something else is rubbing.
K TR2/3/3A Spark Plug Gap? Triumph 4
B TR6 Spark plug gap Triumph 5
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
Jim_Newman Spark Plug Gap Austin Healey 9
B Spark plug gap Triumph 4
F Spark Plug Gap Recommendation Austin Healey 3
R incease spark plug gap with pertronix Spridgets 3
MGTF1250Dave Spark plug gap with high voltage coil Triumph 17
VelodromeRacer Spark plug gap/heat range? Racing 8
R spark plug gap with pertronix ignition and coil Spridgets 6
vping Recommended Spark plug gap MG 26
H Spark Plug Gap Austin Healey 3
T Pertronix = greater spark plug gap? Triumph 4
Woodie spark plug gap Spridgets 9
vping Spark Plug Gap MG 13
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
K TR2/3/3A Testing spark plug wires..... Triumph 11
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
R BJ7 spark plug threads Austin Healey 17
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
S TR2/3/3A Spark plug threads Triumph 10
R '60 3000 Spark Plug recommendations Austin Healey 6
D TR6 Spark Plug Triumph 8
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
dcoplan Spark plug and oil change question Spridgets 9
H BJ8 spark plug reach Austin Healey 32
Jer chasing spark plug threads on head? Spridgets 8
R Spark plug thread Triumph 2
M Restoring proper order to spark plug wires Triumph 36
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
K Old School Spark Plug Road Test? Triumph 6
