Recommended clutch slave cylinder pushrod clearance
62Migit
Hi All,
I'm reassembling the clutch on my project and getting it ready for the first drive. I already know that my clutch slave cylinder pushrod is far longer than replacements (3.75" from hole center to end); it appears to have an additional section welded to the original length. I believe this is too long (especially with unworn clutch components) because I must move the clutch fork (with great effort, as if it is being operated) in order to even install the clevis pin. With the clevis pin installed, is there a prescribed clearance between the slave cylinder and pushrod? This clearance would measure negative (interference) for me at the moment and I don't think this can be right. Am I thinking correctly that a long pushrod could cause the graphite release bearing to be engaged permanently and prematurely wear? Bentley does not address this and just says, "the pushrod is non-adjustable," but mine has been tampered with. Should I just use the replacement pushrod (2.375" per Moss) and leave it alone?
(This has nothing to do with the clutch pedal to master cylinder pushrod clearance, totally different subject)
Thanks!
Mark
DanLewis
Hi Mark,
Is there a chance that your clutch fork is bent? When I replaced the engine and transmission in my bugeye, I discovered that the clutch pushrod that goes into the slave cylinder had been lengthened. Someone had brazed an extension onto the end of it, making it about 3/4" longer than its original length. When I took the transmission off the rear of the engine, I discovered why - the clutch fork was bent. I bought a new pushrod and managed to straighten the fork using heat and a hammer. Put it all back together and everything is fine.
Dan
Gerard
Hi Mark,
Dan
A good chance Dan is right, but can't advise you since you don't specify engine or gearbox. There are several factors to the right combination, including which fork you have, which clutch and which release bearing. See my Tech article.
https://gerardsgarage.com/Garage/Tech/TO_Bearings/tobearings.htm
nomad
Thank's Gerard........very informative. I was not aware of all those combination's.
Kurt.
59diamond
I really envy you guys talking about these things. I just got back from having my bugeye transported to my mechanic. I entered it in a car show and got a first place about a month ago and on the way home the transmission started acting up and the end result was I was able to get it home and the next time I tried to drive it I was unable to shift it at all, and then the fluid from the master cylinder drained out through the slave cylinder onto the garage floor. I am hoping that it is only the slave cylinder and not the clutch as there will be a big price difference between fixing the two. I have my fingers crossed that it is only the slave cylinder.
nomad
Bet its a disintegrated carbon throw out bearing. Just went through the same thing a couple of years ago with my BE.
Have the mechanic make sure that the clutch fork isn't bent, out of line or sloppy on its pivot if it is TO bearing.
Kurt.
59diamond
My mechanic called me with the dire news. The slave cylinder is shot along with a bent carbon throw out and the clutch fork is also bent and I need a new clutch.He is pulling the motor and transmission today to get at everything. I have had the car since May 2012. It was restored in 2003 by a restorer in Washington for the grandmother of the grandson I bought it from after she died. So I don't know anything about what the restorer did to it. My mechanic is very good and has kept the car in good shape so far.He is doing me a big favor by getting right on the problem. He probably has at least a two year backlog of work to do on so many other British cars. When i got to his shop there were two Morgans, a Triumph, a Bugeye and several other British cars being worked on by him and his assistant. He is the best in San Diego County. He is in such demand that he is reluctant to go to British Car Shows because he gets swarmed with questions. It's like when I play golf. I don't tell anyone anymore that I am a retired CPA for the same reason. I did once when I was playing with a retired undertaker and we were joined by two young guys. I told them they were playing with "DEATH AND TAXES".I will just have to pay the Piper.
vintagemechanic Recommended clutch kits Jaguar 3
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
J TR6 Tire Recommended for TR6 Triumph 3
Csarneson Seat Foams and recommended interiors? Austin Healey 13
T TR2/3/3A What air pressure is recommended in my Hoosier tires? Triumph 1
C Recommended reproduction wheels? Austin Healey 29
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
W TR6 Dashboard Recommended finish Triumph 5
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
MikeAH100M FYI - Hardie Board for Heat Shields not Recommended Austin Healey 9
C TR4/4A Recommended Books Triumph 8
R BJ8 with Servo, Is the 7/8 Master Cylinder recommended ?? Austin Healey 7
60TR3A What's The Recommended Stainless Steel Exhaust for '63 BJ7? Austin Healey 5
RickB Recommended seller of Spridgety bits Spridgets 4
I Recommended lubricant/fluid questions for 948 Spridgets 8
PatGalvin Engine Improvements Recommended? Triumph 6
T MGA Recommended order for building MGA front susp MG 1
T Recommended fuel pressure Spridgets 32
CinneaghTR Recommended Paint Shop near Baltimore, MD? Triumph 8
CinneaghTR Recommended Paint Shop near Baltimore, MD? Restoration & Tools 0
angelfj1 Recommended Lubricant for Lucas Windscreen Wiper Restoration & Tools 4
jjbunn Driving on two wheels - not recommended. Triumph 51
T manufacture's recommended fluids Jaguar 1
2wrench Hylomar recommended, but hard to find. Triumph 14
B Recommended Rover Reading Rover / Land Rover 1
B Recommended Reading MG 5
vping Recommended Spark plug gap MG 26
Ed_K Recommended break in for rebuilt engine ? Austin Healey 7
R Recommended Tire Size? Austin Healey 5
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
Lin Brake/Clutch Fluid Austin Healey 11
