Recommended Lubricant for Lucas Windscreen Wiper
angelfj1
What type of lubricant is recommended for the gear box on these windscreen wiper units? Mine has a steel worm (on the end of the motor shaft) and a nylon gear.
Platinum
Go for "modern" silicone grease, Frank. Less chance of degrading the old synthetics and certainly more long lasting than petrochemical lubes.
Platinum
Sure. Look for Mobil. I think you MAY even find it at WallyMart.
I Recommended lubricant/fluid questions for 948 Spridgets 8
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
vintagemechanic Recommended clutch kits Jaguar 3
J TR6 Tire Recommended for TR6 Triumph 3
Csarneson Seat Foams and recommended interiors? Austin Healey 13
T TR2/3/3A What air pressure is recommended in my Hoosier tires? Triumph 1
C Recommended reproduction wheels? Austin Healey 29
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
W TR6 Dashboard Recommended finish Triumph 5
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
MikeAH100M FYI - Hardie Board for Heat Shields not Recommended Austin Healey 9
C TR4/4A Recommended Books Triumph 8
R BJ8 with Servo, Is the 7/8 Master Cylinder recommended ?? Austin Healey 7
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
60TR3A What's The Recommended Stainless Steel Exhaust for '63 BJ7? Austin Healey 5
RickB Recommended seller of Spridgety bits Spridgets 4
PatGalvin Engine Improvements Recommended? Triumph 6
T MGA Recommended order for building MGA front susp MG 1
T Recommended fuel pressure Spridgets 32
CinneaghTR Recommended Paint Shop near Baltimore, MD? Triumph 8
CinneaghTR Recommended Paint Shop near Baltimore, MD? Restoration & Tools 0
jjbunn Driving on two wheels - not recommended. Triumph 51
T manufacture's recommended fluids Jaguar 1
2wrench Hylomar recommended, but hard to find. Triumph 14
B Recommended Rover Reading Rover / Land Rover 1
B Recommended Reading MG 5
vping Recommended Spark plug gap MG 26
Ed_K Recommended break in for rebuilt engine ? Austin Healey 7
R Recommended Tire Size? Austin Healey 5
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
S TR2/3/3A tach cable lubricant Triumph 4
simon1966 Steering box lubricant Austin Healey 17
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
G TR2/3/3A Control head Lubricant? Triumph 3
A TR2/3/3A TR-3A wiper lubricant [tubes and cable] Triumph 1
J TR4/4A TR4A Wiper Motor Lubricant Triumph 12
Stinger TR4/4A TR4A Steering Box Lubricant Triumph 6
tahoe healey lubricant SL2 Austin Healey 2
V Fluid/lubricant ID on "new" Midget??? Spridgets 9
eschneider Help! Rover P3500S gearbox lubricant???? Rover / Land Rover 4
W Wiper motor, etc... proper lubricant Spridgets 19
J Window guide lubricant, or not? Austin Healey 2
I TR6 TR6 trunion help - how tight, correct lubricant? Triumph 24
HAN8L1965 Steering Rack Lubricant ? Spridgets 4
G ARP Assembly Lubricant....how to use the stuff Triumph 9
fad64b Steering Rack Lubricant Triumph 14
R Lubricant Type for Tranny Austin Healey 10
B Lubricant Question Spridgets 6
A transmission lubricant Austin Healey 4
danielnorton Rear Axle Lubricant Spridgets 5
