Recommended lubricant/fluid questions for 948
ichthos
What do you guys run for your engine and transmission? My book suggests 20/50 engine oil for both the engine and transmission - is this correct? Also, what type of fluid do you use for the master cylinder? thanks, Kevin
bigjones
Bronze
As far as engine oil, I've switched to Valvoline Racing Oil 20w-50 from the local auto store. The "racing" is hype but it does contain zinc which is important in these old technology engines.
Cheers!
bthompson
I've read that Castrol 20w-50 contains enough zinc for old engines as well. (But <span style="font-style: italic">only </span>the 20w-50 has it.) Castrol LMA brake fluid is safe for the old natural rubber bits in the brake system.
At least, that's the last I'd heard...formulations may have changed recently, as they do.
I
ichthos
Thanks for the information. I have never put engine oil in a transmission before - is it true I should be 20/50 engine oil in the transmission?
Kevin
bigjones
Bronze
Not many people on the forum today.
I don't have a 948 but Haynes says to use 20w-50 for the gearbox.
(except for the 1500 cc model - that takes Hypoid gear oil, 90EP for top-up and 80EP for a refill)
While I'm at it:
All models take Hypoid gear oil 90EP for the rear axle.
Also says to use 20w-50 for the carb dashpots.
Cheers!
I
ichthos
I knew.there wouldn't be many people on the forum today. I figured most would be out having fun driving their cars. I sure hope I can get mine up and running before the good weather ends. Both my manuals say to use 20/50 oil for the transmission, but I have never heard of using engine oil in the transmission before. The PO definitely used 90wt. Of course he used grease for the steering rack too. Thanks for your help.
Kevin
Platinum
Just logged on since this AM... The lads are right, 20/50w or straight 30w in that gearbox, Kev. :thumbsup:
There are some needle rollers in there, they and the "syncros" don't like the gear lube.
sim
My book says 30W in the transmission. BTW it was taken from the owners manual.
It must have worked as the transmission lasted 50 years. Have had this car since 1973
NO such oil 20/50 in 1958
angelfj1 Recommended Lubricant for Lucas Windscreen Wiper Restoration & Tools 4
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
vintagemechanic Recommended clutch kits Jaguar 3
J TR6 Tire Recommended for TR6 Triumph 3
Csarneson Seat Foams and recommended interiors? Austin Healey 13
T TR2/3/3A What air pressure is recommended in my Hoosier tires? Triumph 1
C Recommended reproduction wheels? Austin Healey 29
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
W TR6 Dashboard Recommended finish Triumph 5
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
MikeAH100M FYI - Hardie Board for Heat Shields not Recommended Austin Healey 9
C TR4/4A Recommended Books Triumph 8
R BJ8 with Servo, Is the 7/8 Master Cylinder recommended ?? Austin Healey 7
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
60TR3A What's The Recommended Stainless Steel Exhaust for '63 BJ7? Austin Healey 5
RickB Recommended seller of Spridgety bits Spridgets 4
PatGalvin Engine Improvements Recommended? Triumph 6
T MGA Recommended order for building MGA front susp MG 1
T Recommended fuel pressure Spridgets 32
CinneaghTR Recommended Paint Shop near Baltimore, MD? Triumph 8
CinneaghTR Recommended Paint Shop near Baltimore, MD? Restoration & Tools 0
jjbunn Driving on two wheels - not recommended. Triumph 51
T manufacture's recommended fluids Jaguar 1
2wrench Hylomar recommended, but hard to find. Triumph 14
B Recommended Rover Reading Rover / Land Rover 1
B Recommended Reading MG 5
vping Recommended Spark plug gap MG 26
Ed_K Recommended break in for rebuilt engine ? Austin Healey 7
R Recommended Tire Size? Austin Healey 5
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
S TR2/3/3A tach cable lubricant Triumph 4
simon1966 Steering box lubricant Austin Healey 17
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
G TR2/3/3A Control head Lubricant? Triumph 3
A TR2/3/3A TR-3A wiper lubricant [tubes and cable] Triumph 1
J TR4/4A TR4A Wiper Motor Lubricant Triumph 12
Stinger TR4/4A TR4A Steering Box Lubricant Triumph 6
tahoe healey lubricant SL2 Austin Healey 2
V Fluid/lubricant ID on "new" Midget??? Spridgets 9
eschneider Help! Rover P3500S gearbox lubricant???? Rover / Land Rover 4
W Wiper motor, etc... proper lubricant Spridgets 19
J Window guide lubricant, or not? Austin Healey 2
I TR6 TR6 trunion help - how tight, correct lubricant? Triumph 24
HAN8L1965 Steering Rack Lubricant ? Spridgets 4
G ARP Assembly Lubricant....how to use the stuff Triumph 9
fad64b Steering Rack Lubricant Triumph 14
R Lubricant Type for Tranny Austin Healey 10
B Lubricant Question Spridgets 6
A transmission lubricant Austin Healey 4
danielnorton Rear Axle Lubricant Spridgets 5
