TR2/3/3A Recipe for a TR2
Redoakboo
Thanks for the kind words. Tush, you're right. You have to turn the key half way between lock and unlock and use it to pull the lid up. Funny it took 4 years to add a handle. Steve, it's too well documented to let photobucket ruin it. Once I'm done I'll compile the journey into a PDF I can share with anyone interested. These old cars need all the help we can give their owners to keep the fun alive!
John,
My 54 has a handle with the key hole in the middle.
Dick
CJD
CJD
The lantern clips are the 2 little springs that center the stator tube inside the steering column. Post #81 has several good pictures of these spacers.
I had to build the OD wiring, but I used vintage wiring and tried to make it as close to original as possible...that is shown in post #84.
CJD
CJD
If you have door handles on your TR2, then they are TR3/3A doors. The TR3 doors still had wood across the top, while the TR3A were all metal except for 2 oak blocks for the sidescreen mounts to screw into. No TR2's were built with handles, and thus their sidescreens required zipper openings to open the doors from the outside. The only key locks were the ignition and boot.
Redoakboo
John, How do you pull up a particular post? # 81 & #84
CJD
CJD
The post number is in the upper right corner, at the beginning of each post. For example, this is post number 187. Just scroll to the number you want to view. You may have to change pages, but normally when I provide a post it has you on the page you need.
Well, the TR2 normally had no handle on the trunk. It has a key tumbler in the middle, and then a fig leaf covered coach lock on each side. A handle would be helpful, though, as you must use the key to pull the trunk open as designed.
GAJ
Hello John,
i think even the TR2's did away with the zippers when they went to the sliding window sidescreens.
Graham.
Redoakboo
Hello John,
Graham.
My 54 Long door side windows have flaps that pivot up to get to the opening cord. The flaps are held down with 4 tenax fasteners.
Dick
CJD
CJD
The flaps are different...they are just the way the sidescreen is assembled. As it came from the factory the TR2's would have a zipper in the middle of the flap.
The introduction of the sliding window was at TS8637, so the first TR3. Until then there were no sliding windows and a zipper in the sidescreen flap to reach into the door and open with the pull cord.
This is according to the judging guide..so it is possible there were some odd balls around the change date.
GAJ
Sorry the image appears to be upside down.
This production report for my TR2 states sliding sidescreens
Graham
CJD
CJD
Interesting, Graham. The judging guide does say they were installed on the "GT" variants. Do you know what the "LMX H" spec is? I assume in those days you could order anything they had, thus the differences.
ckeithjordan
See attached back of Factory Trace.
M Recipe? Spridgets 11
G Recipe for disaster? Triumph 6
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
