TR6 Rear panel paint ccode
brick7
Hi Guys,
I purchased a 72 TR6 that was restored and had a repaint..The rear panel was painted the same as the rest of the body...Does anyone know of a paint code for the rear panel..I know that they were always painted black, and know it wasn't gloss black..Either a flat, matt, or a satin..any suggestions would be appreciated .
Thanks,
Brick7
poolboy
Hey Brick, I can't tell you the black satin paint code, but that panel..that panel is called the "rear valance"'
M_Pied_Lourd
tomshobby
I just did mine with urethane satin black from Eastwood.
M_Pied_Lourd
Looks great Tom!
Cheers
Tush
vette MGB Rear Fender Dog Leg Patch Panel MG 3
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
Got_All_4 TR6 Rear Panel Reflector off a parts car? Triumph 8
Tinkerman TR2/3/3A Rear upholstry panel screws Triumph 2
toysrrus TR6 Rear deck panel Triumph 4
F How is the leading edge of the rear quater trim panel fixed on a AH BT7? Austin Healey 16
J TR2/3/3A Interior rear back panel for 60 TR 3A Triumph 7
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
B Installation of New Rear Seat Surround Panel for a BJ7 Austin Healey 8
L BJ8 Rear Interior panel fitting Austin Healey 7
C Rear seat panel BJ7 & ignition coil help Austin Healey 14
luke44 TR2/3/3A TR3A Rear Trim Panel Triumph 7
60Bugeye New Center Rear Panel or Repair? Spridgets 20
M_Pied_Lourd TR2/3/3A TR3A Rear Close Out Panel Triumph 5
KVH TR4/4A TR4A--Padded Rear Interior Panel--Behind The Seats Triumph 5
ekamm Rear Closeout Panel Triumph 9
L BJ8 dome nuts on rear interior panel Austin Healey 5
tosoutherncars rear panel replacement? Spridgets 10
C Lotus Elite rear window / panel disaster Lotus 4
crya Interior Rear Panel Removal Thread Austin Healey 2
G TR2/3/3A TR3 rear apron panel Triumph 2
jjbunn TR6 TR6 rear panel: always black? Triumph 33
chrisc Rear Bulkhead Panel MG 16
AUSMHLY Grommet in rear battery cable panel Austin Healey 1
jimbar Replacing rear valance panel Triumph 3
N Missing Rear Seat Back Panel Austin Healey 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
