TR4/4A TR4A--Padded Rear Interior Panel--Behind The Seats
KVH
Guys and Gals:
How do I remove that padded panel behind my seats (i.e. in front of the gas tank)? I don't see any screws or snaps, and yet it's tightly fit into the back wall of the interior. The car was originally a hard top model.
Are there push clips back there? Or, am I headed for the supreme joy of gas tank removal just to remove that silly panel?
JRC
Maybe it was glued on?
HerronScott
For the TR4A, I believe it should be the same rear panel whether soft top or Surrey top and it should be screwed in with chrome screws with cups. There should be 4 or 5 along the top edge and then 1 on each side about half-way down and I believe there were 4 at the bottom as well as the parts manual lists 11 screws and cups. Note that the TR4 did have a different rear panel with a Surrey top since with the soft top the rear section and sides lifted and covered the top frame when down.
You mention padded though and there isn't really any padding in the original TR4A rear panel. The same board and vinyl covering with vertical heat seams similar to the door panels. Do you have any pictures of what your car has installed? I don't suppose your car came with the occassional rear seat (not that I've seen one with a TR4A and the parts manual only shows 1 part number for the rear squab trimmed assembly).
Scott
KVH
KVH
On mine, there are no visible screws or hardware fittings, but you're correct that the panel resembles the door panels, rather than the foam padded piece like on the TR4. My manual indicates that some trim pieces in the rear are glued with rubber cement, and I wonder if that's all I have here.
HerronScott
The rear wheel arch covers and the triangular trim pieces down by the doors (B post reinforcement pad assembly) should be the only glued pieces, but maybe yours is just glued.
Scott
Stinger TR4/4A TR4A Padded Dash Installed Weatherstrip Question Triumph 7
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
