I am working on my front suspension on my 1961 TR3A. When I got to the point of removing the drivers side front lower wishbone arm, I find that I can't get it off the frame member fulcrum pin because the steering box is blocking it from sliding off the fulcrum pin.
Do I have to somehow lift the steering box up out of the way enough to slide the wishbone arm off the pin? Or am I missing some special way to get it off?
If I have to lift the steering box up out of the way, will the steering box lift if I just remove the bolts that mount it to the frame? Thanks for the help!!
Regards,
Bob
Regards,
Bob
