Putting a 1275 in a rubber Bumper car
I have decided to put a 1275 in a rubber bumper car, and I'm not sure about the brake lines. Will the junction and lines be too close to the exhaust? I'm thinking that they should be moved, but I'm looking for advice from people that have gone done this before.
Thanks
RickB
lbcnewbie (Ed in NC) did it here.
I cannot remember about the brake lines though, but someone else here might - BillM?
aeronca65t
No problem with brake line clearance on my 1500 car (race car) converted to 1275.
I'm using a header, but it doesn't look like the stock manifold would be a problem either.
You will need to change the hydraulic line routing to the clutch slave cylinder.
RichBall
Trevor,
Take a look at Ed's (lbc_newbie) flicker link in his signare. He has lots of pictures of his resto there. He pick up the car with the 1275 already installed, but pretty much redid everything.
Gerard
Never done it myself, but you could always add a heat shield if you're concerned about it. Check the hot rod web sites some of these specialty stainless/ceramic shields. They're not terribly expensive. I used one on an XKE w.5.0 Ford V8 to shield the starter from the header. Stater wouldn't work right when it got too hot. Worked to solve the problem.
Trevor Jessie
Thanks,
I'm pretty sure there is clearance, I just wasn't sure about the heat. I think I'll leave them as they are.
Trevor Jessie
Why am I putting a 1275 in a rubber bumper car? Because I was given a rubber bumper car with a bad engine. People started giving me grief about parting it out and I started feeling guilty. I was looking for a 1500 engine for the car when I ran across a '69 parts car for a reasonable sum. So ... I'm going to debumper the car and install the 1275 and ribcase. I'm not sure what I'm going to do with the car ... I may donate it. It is just another way to procrastinate painting my Sprite. ;)
Jim_Gruber
Trevor,
You just want to keep with Ugly Bug moniker. Even in black primer Ugly Bug is indeed cool.
nomad
Trevor, I've got a 1500 that has supposedly been freshly overhauled. It came with a bulk parts purchase along with the associated hardware.[trans, intake] also have a new set of headers. All to the right guy for a nominal price.:encouragement:
Kurt
Trevor Jessie
Too late ... I'm committed to the 1275. (I like them better anyway). Bumper and fenders came off today. It needed a lot of cleanup, and the only way to really get the engine compartment tidy is to disassemble the front clip. I'll need to patch the battery tray and tweak one of the frame horns before moving forward. I'll be using the heater from the '69 so I'll be relocating the aperture in the shelf and making a relief area for the old style blower. I'm going to use as many as my old spares as possible (even it it means a little more fabrication time. In fact, I have a fiberglass bugeye nose that I briefly considered ... but then I'd feel obligated to do some sort of special treatment to the rear. Hopefully this weekend I can finish parting out the '69 and decide if I'm going to use those fenders or just patch up the '76 fender turn signal holes.
G
'76 'eh? TKC 2847 head and flat top pistons? I could use som'ma those.
JPSmit
You can McGyver the signal lights into the 1500 signal holes if it is easier
Trevor Jessie
Nope, the pistons were dished (and ruined).
I know I can make the signal stay in the holes, but I like to cut, weld and grind. :smile:
nomad
Good for you, Trevor. Looks like you're making up a fairly low cost driver. Things seem a little slow and its nice to know something is getting done. Keep us up to date!
Kurt.
Jim_Gruber
Trevor,
I will have a need for A-Arms, front spindles and calipers coming up, assuming this is a disc wheel Spridget, if you are going to part this one out.
Jim_Gruber
Front sway bar as well.
Trevor Jessie
I have available...
Definite: sway bar, spindles, calipers, steering arms
Maybe: disc wheel hubs.
Thor Putting in 1275 motor into 1500 Midget Spridgets 4
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
algot1901 Putting the doors on Other British Cars 11
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
69MGC MGC Putting a 12v battery in the trunk MG 10
R TR2/3/3A Putting windshield back together Triumph 13
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
F Chocking the rear wheels and putting in gear when jacking up the front Austin Healey 8
2billydavies TR2/3/3A looking for suggestions on putting engine back in Triumph 17
S Putting my 68 on the road. Spridgets 12
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
S TR2/3/3A putting the sleeves into the block Triumph 7
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
K TR2/3/3A Putting traction bars on a TR3? Triumph 3
T TR5/TR250 Downside to putting TR250 fan on TR3 Triumph 13
K TR4/4A Putting H6 SU's on a TR4A intake manifold. Triumph 1
B TR6 Putting a 205 75 tire on a tr6 Triumph 4
B TR6 Putting a Tr4 top on a Tr6 Triumph 14
G Where you 6 guys putting fuel pumps? Triumph 10
J Putting the IRS on stands ??? Triumph 5
J Putting BE dash together from box of random parts- Spridgets 12
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
J AH 1962 - Putting on Front Fenders Austin Healey 8
G putting on new top MG 5
T First time putting front hubs on - any tips Triumph 7
doughairfield TR4/4A Putting the motor back in the TR4 Triumph 9
Got_All_4 TR2/3/3A Putting a J type in a TR3A Triumph 14
hondo402000 TR6 TR6 Final Paint pics and Putting it back together Triumph 31
K TR4/4A Putting aTR4 motor and trans in a TR3 Triumph 4
T Putting the clutch master cylinder back together Triumph 13
UmmYeahOk Dammit! Quit Putting Holes in My Car!!! Triumph 32
pjsmetana Spitfire Putting the Spit in a car show saturday Triumph 2
liljohnTR250 TR5/TR250 putting new top on TR250 Triumph 7
J Putting my head back together. Triumph 3
Newkie Putting weatherstipping on windscreen MG 11
J putting the diff back together tonight Triumph 2
7 Putting the front wheel bearing back together. Triumph 0
L Putting Humpty Dumpty Back Together Again Austin Healey 3
GregW Putting the windshield back together Austin Healey 10
Steve Putting it all back together MG 3
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
