Pro and Con of Negative Ground conversion
Frank C.
Ok, Winter is coming and I'm thinking of converting my BJ8 to negative ground (like I don't have enough other projects to do on the Healey!). So far, other than a better choice on radios, I haven't seen a compelling reason to make the conversion. I'm interested in the groups opinions.
Thanks in advance ...
sky
Member
Frank, The only reasons to switch to neg ground would be for converting from a generator to alternator, electronic ignition (more choices),or as you stated, more choices of radios. The only other polarity sensitive equipment I can think of is the fuel pump, but pos ground pumps are readily available. So...if it ain't broke don't fix it. Sky
Frank C.
Frank C.
Sky,
Thanks for the feedback ... I tend to agree. I was just wondering if there were conflicting views in "Healey Land" but so far I guess not.
Thanks again for your input.
Randy Harris
As long as you are not going for concourse points, negative ground conversion is an excellent upgrade, especially if you are thinking about an alternator at some point. An alternator conversion will enhance the car's reliability and improve your lighting immeasurably. You can add modern, more powerful headlights, driving lamps without worry, idle in traffic without drain on the battery, allow an infinite selection of accessories including modern radios. I think it's a good idea.
Coop
'66 BJ8, '68 E-Type OTS
mountainman Pro & Con's of Pertronix vs Points Triumph 43
nichola TR6 Procar Pro-90 Seats in the TR6 Triumph 21
M General Tech Pro restoration Triumph 0
Got_All_4 TR2/3/3A Super pro bushings Triumph 2
T TR6 Go Pro video of a short drive Triumph 3
SkinnedKnuckles Just Curious - Where are the Old Pro's Triumph 28
Alan_Myers TR2/3/3A Carrillo Pro-A Conrods in TR2/3/4? Triumph 11
aeronca65t No More Pro-Rally!! Other Cars 6
A Pro-Tec lining for my boot MG 7
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
P TR2/3/3A "MaXpeedingRods" con rods good or bad? Triumph 3
DornTRoriginal TR2/3/3A TR3 Head Gasket Questions Con't Triumph 3
2billydavies TR2/3/3A removing con rod from crankshaft Triumph 4
dklawson GT6 GT6 Con Rod Bolts & Grant Piston Rings? Triumph 5
Superwrench con-rod dimension Austin Healey 15
M Still con-fused about fuses Triumph 22
walshja 2010 British by the Sea registration is open - Con Spridgets 0
J What is going on with this con rod? Triumph 11
Baz Con-fused... Spridgets 2
prb51 TR2/3/3A Con Rod Bearings TR3 Triumph 10
P Positive to Negative Conversion Austin Healey 1
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
M BJ8 Positive-Negative Ground Conversion Austin Healey 7
doc50 Nash Metro Positive to Negative Ground Other British Cars 2
G TR4/4A Negative Ground Conversion Question Triumph 11
M TR2/3/3A Positive or negative ground? Triumph 6
P Bugeye Negative Ground Spridgets 15
S MGA 1956 MGA negative ground, True Spark Ignition distributor MG 3
Jim_Gruber Am I set up as Positive or Negative Ground? Spridgets 12
M Negative ground conversion : what about OD ? Austin Healey 9
M Question about positive vs negative ground Spridgets 13
K TR2/3/3A Converting to Negative Ground....... Triumph 12
L The Ultimate Negative Ground Conversion Thread Austin Healey 2
J How can I tell if I have a negative ground tach? Austin Healey 5
M_Pied_Lourd TR2/3/3A Identifying positive or negative ground.... Triumph 14
maxwedge5281 changeover to negative ground in my bn6 Austin Healey 9
A How install a radio with negative mass Austin Healey 3
Marvin Gruber MGA Negative grd- fuel gauge question MG 18
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
Lukens TR2/3/3A Converted TR3A to negative ground. Triumph 0
P TR4/4A Positive/Negative Earth Dilemma TR4A Triumph 11
C Positive or Negative Earth Triumph 15
E Positive ground or Negative ground. What have you? Austin Healey 12
TulsaFred Negative Ground Conversion- inconsistent guidance Spridgets 13
S positive and negative ground Triumph 7
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
memphis Positive to Negative Conversion Austin Healey 2
R Negative Camber 78 Eclat Lotus 8
I Negative grounding questions Spridgets 12
AUSMHLY Is there a negative wire on the directionals? Austin Healey 30
