piston supplier
Hoghead
Who supplies modern forged pistons for a 3000 engine. A bit higher compression may be nice - 10:1 ?
No luck in navigating Wisecos website
dougie
Arias can also design/manufacture anything you have in mind. As Randy advised, this type of quest requires direct communication with the engineers involved.
https://www.ariaspistons.com/
dougie
Just checked, my custom dome topped Arias racing pistons were $964.50 US, 2 years ago...
busybrit TR6 AE Piston supplier, when you only want one ! Triumph 2
K TR2/3/3A Piston slap? Triumph 3
T TR2/3/3A valve guides and piston clearance Triumph 6
Simmo TR2/3/3A Something is eating away at my Piston Liners Triumph 15
D Separating the piston from the connecting rod. Spridgets 9
J Piston Coating Austin Healey 3
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
KVH General Tech Removing Piston Wrist Pin Triumph 2
sail TR4/4A Piston Ring Question Triumph 6
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
J TR2/3/3A 87mm piston ring gaps Triumph 15
Jayplum TR2/3/3A TR3 Piston Sleeves Triumph 36
M TR2/3/3A How many miles to seat piston rings? Triumph 4
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
BJ8Healeys Disc brake piston seals Spridgets 2
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
M TR2/3/3A Please Help ID This Piston Triumph 6
Got_All_4 TR6 Are these piston nitrated coaded Triumph 5
J TR2/3/3A 83 to 87mm Piston Considerations Triumph 7
Gerard 1275 piston ID Spridgets 2
HighAltitudeTR3 TR2/3/3A Piston Slap đź‘‹ Triumph 12
M TR2/3/3A Sleeve and Piston Sizes Triumph 6
Got_All_4 TR6 Depth of the metering needle in the air valve piston Triumph 12
steveg Piston options for Healey Austin Healey 12
T TR2/3/3A SU Piston Drop Test Triumph 4
C TR2/3/3A Piston gap orientation Triumph 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
T General Tech Brake caliper - piston stuck Triumph 4
2billydavies TR2/3/3A need an educational lesson about piston rings Triumph 14
KVH TR4/4A Piston Size Measurement on Rebuild Triumph 4
Jake OD unit operating piston rings? Austin Healey 1
JPSmit Brake piston removal - McGyvered some tools Restoration & Tools 0
W TR2/3/3A Piston and Liner Triumph 2
tinman58 TR6 Piston clearance Triumph 4
T TR4/4A Overdrive piston is sticking Triumph 9
TomMull caliper piston tool Restoration & Tools 11
T General Tech How loose can a piston liner be? Triumph 2
M Healey 100-4 Piston Crown Clearance needed to Cylinder Head Austin Healey 3
oxford piston rings Austin Healey 4
T TR2/3/3A caliper piston stuck Triumph 12
S TR6 Clutch slave piston shooting out during bleeding Triumph 8
RedTR3 TR2/3/3A TR3 Piston Sets Triumph 10
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
A TR2/3/3A Tr3 / 4 piston clearances Triumph 7
M Healey Overdrive Upgrade with Larger Piston & Stiffer Springs Pros/Cons? Austin Healey 12
