Piston... MIA
poolboy
Piston... MIA
The guys over on the Forum where I spend most of my time had never seen anything quite like this. I thought you'd want to take a look, too. The coolant is from removing the head, not contributing to the catastrophe
I had a leaking needle valve, took the middle carb off, replaced the valve, started the engine;new valve also leaked and flooded the carb; I killed the engine.
I then pulled the fuel line off the middle carb, shot the needle valve with carb cleaner thru the inlet nipple
and restarted the engine.
Within a couple seconds I heard an awful rattle and the engine died.
I restarted, no rattling but running poorly so I shut it down. The noise, the rattling reminded me of a chain saw loosing it's chain.
My thought shifted to the timing chain. I checked the cam timing by comparing the valve lash with the damper marks... Not a problem, so I pulled out the Compression Gauge.
Spark plug #6 looked like this
As to what exactly happened..so far it's all speculation. And I guess really doesn't matter at this point.
Lucky in a way that I have an original, used but un machined, short block to work with.
TR4nut
Re: Piston... MIA
Incredible! Have you pulled the pan yet?
TR4nut
Re: Piston... MIA
Forgot to ask- how's the head look itself? Did you get a bent valve out of it or more? That sparkplug took a beating.
Deleted member 8987
Re: Piston... MIA
Hydraulic lock. Most likely a bent rod, and check the crank for straight and cracks. Have the block magnafluxed, and the bore carefully checked, to make sure you didn't push a wall out.
Remove engine and start over, hope for the best.
poolboy
poolboy
Re: Piston... MIA
I haven't dropped the pan yet, Randy. I've been working in the engine bay and cockpit.
Probably Wednesday or Thursday I'll clean out the pan.. a day or two before I pull the engine.
The valves look pretty good, I wiped the oil and soot off and I can see where they got peened. It's going to the shop for a better inspection.
poolboy
poolboy
Re: Piston... MIA
What was the hydraulic part in that cylinder ?
The bore ? The bore... You can imagine what the cylinder walls looks and feels like like
:crazy:
Deleted member 8987
Re: Piston... MIA
If you filled it with petrol, and cranke3d it on a compression stroke, it won't compress.........it breaks things. Last item to go was the piston. We don't know what the first one was, but generally, when you hydraulic-lock a cylinder, rod bends, and possibly cylinder wall gets pushed out. Hone it, run a new ring carefully down the wall with the head of the new piston (with no rings) checking every 1/4 to 1/2" for space between ring and wall is a quick check. Not much point in doing a new piston and rings and having to do it all again. Have a machine shop check the rod for straight......if it's bent, it will usually be obvious.
Deleted member 8987
Re: Piston... MIA
It's really hard to tell from the one picture, but the rod sure looks bent from this angle. Leaning forward...almost touching the front wall...the angle just doesn't look right for the length of the rod.
poolboy
poolboy
Re: Piston... MIA
There wasn't an excess of gas in either 5 or 6. The flooding carb was serving 3 & 4.
Honing will not be adequate.
Deleted member 8987
Re: Piston... MIA
You see those roughly parallel marks just above the right end of the gudgeon pin? Look like stretch marks? I'd be looking there first. Usually, at idle a piston just doesn't do that. I am thinking you had something in there.....coolant or gas.
poolboy
poolboy
Re: Piston... MIA
Not coolant..as I said, it spilled when I lfted the head. Head gasket was just fine.
As far as the cylinder walls I can see the gouges and feel them as well. My guess it was because the piston broke and chewed itself up with each stroke, pulling debris into the sump scraping and bouncing against the walls along the way. That was the rattling noise and once it all got dragged below the noise stopped.
Since I have an unmolested short block, I'm really not counting on salvaging anything much from this block.
I've removed the cam followers and if the cam itself looks as good, I'll reuse it.
Brosky
Re: Piston... MIA
As I said earlier, I'd like to see the other cylinders and pistons when you get it apart before passing any judgement. To many unknowns that MAY get answered with a look at the other parts.
TR3driver
Great Pumpkin - R.I.P
Re: Piston... MIA
Well, that sucks!
Makes me appreciate the old wet liner TRactor engine though. I once repaired a 4-pot where not only had the piston gone AWOL but the wrist pin went through the cylinder liner. Cleaned up the mess, replaced the rod, new set of liners & bearings plus a new cylinder head (the broken valve head also beat the valve seat to pulp), got it running again without even removing the front apron!
And all that was laying on the ground in the snow. I threw a tarp over the top and stuck a space heater underneath, just so my fingers wouldn't stick to the metal.
CJD
Re: Piston... MIA
And I thought all you guys in sunny SoCal had no idea what the rest of us put up with!!
John
TR3driver
Re: Piston... MIA
I didn't always live in CA ...
HerronScott
Re: Piston... MIA
Hard to imagine it could disintegrate without even more damage to the head and cylinder walls.
Scott
DNK
Re: Piston... MIA
Ken, you sure that wasn't ah Audi motor?? :wink:
Brosky
Re: Piston... MIA
If you look under a magnifying glass, I'm sure you'll see more than the low resolution shots here.
K TR2/3/3A Piston slap? Triumph 3
T TR2/3/3A valve guides and piston clearance Triumph 6
Simmo TR2/3/3A Something is eating away at my Piston Liners Triumph 15
D Separating the piston from the connecting rod. Spridgets 9
J Piston Coating Austin Healey 3
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
KVH General Tech Removing Piston Wrist Pin Triumph 2
sail TR4/4A Piston Ring Question Triumph 6
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
J TR2/3/3A 87mm piston ring gaps Triumph 15
Jayplum TR2/3/3A TR3 Piston Sleeves Triumph 36
M TR2/3/3A How many miles to seat piston rings? Triumph 4
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
BJ8Healeys Disc brake piston seals Spridgets 2
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
M TR2/3/3A Please Help ID This Piston Triumph 6
Got_All_4 TR6 Are these piston nitrated coaded Triumph 5
J TR2/3/3A 83 to 87mm Piston Considerations Triumph 7
Gerard 1275 piston ID Spridgets 2
HighAltitudeTR3 TR2/3/3A Piston Slap 👋 Triumph 12
M TR2/3/3A Sleeve and Piston Sizes Triumph 6
Got_All_4 TR6 Depth of the metering needle in the air valve piston Triumph 12
steveg Piston options for Healey Austin Healey 12
T TR2/3/3A SU Piston Drop Test Triumph 4
C TR2/3/3A Piston gap orientation Triumph 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
T General Tech Brake caliper - piston stuck Triumph 4
2billydavies TR2/3/3A need an educational lesson about piston rings Triumph 14
KVH TR4/4A Piston Size Measurement on Rebuild Triumph 4
Jake OD unit operating piston rings? Austin Healey 1
JPSmit Brake piston removal - McGyvered some tools Restoration & Tools 0
W TR2/3/3A Piston and Liner Triumph 2
tinman58 TR6 Piston clearance Triumph 4
T TR4/4A Overdrive piston is sticking Triumph 9
TomMull caliper piston tool Restoration & Tools 11
T General Tech How loose can a piston liner be? Triumph 2
busybrit TR6 AE Piston supplier, when you only want one ! Triumph 2
M Healey 100-4 Piston Crown Clearance needed to Cylinder Head Austin Healey 3
oxford piston rings Austin Healey 4
T TR2/3/3A caliper piston stuck Triumph 12
S TR6 Clutch slave piston shooting out during bleeding Triumph 8
RedTR3 TR2/3/3A TR3 Piston Sets Triumph 10
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
A TR2/3/3A Tr3 / 4 piston clearances Triumph 7
M Healey Overdrive Upgrade with Larger Piston & Stiffer Springs Pros/Cons? Austin Healey 12
