I recently received set of pistons and liners for my TR3, part 814-305 from LBC. Included were the FO8 liner gaskets. However, these were steel. I was under the impression that Standard Triumph discontinued using the steel gaskets more than 50 years ago because of corrosion issues. (I know these have been available aftermarket.) I had also assumed that the liner kits came with copper gaskets (the last one I bought did but that was some time ago).
Is anyone aware of this? Is there any reason for using steel? Can I safely and simply substitute the copper gaskets? I mic’d the gaskets at .014, which is a thousandth over standard, I think, and being almost totally resistant to crush, the steel would seem to be a good solution to low liner height, a condition I don’t have. I am most concerned about corrosion. I’ve sent a similar inquiry off to LBC.
Tom
Tom
