TR2/3/3A Penrite into TR3b steering box - dump and go?
MGTF1250Dave
Aloha Skip,
In my opinion, I would top up the steering box and drive. The other alternative is to remove/loosen the front cover plate and that should allow most of what is in there to drain out. Then you can refill with the Penrite and most of the contents will be Penrite. I think the most important thing is to have some lubricant in the box. I have used 90W 140 gear oil and some grease smeared in the worm in the two TR3s I have owned without apparent damage.
prb51
Dump and go.
I put the Penrite in my leaky box and the 90 weight cont. to leak out until depleted and the Penrite stayed in place. great stuff.
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
M TR2/3/3A TR3 Steering: Penrite v. Snythetic Triumph 4
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
AngliaGT TR2/3/3A Value of a One Owner,Excellent Condition TR3B ? Triumph 12
glemon TR2/3/3A TR3B Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
P TR2/3/3A TR3B SU carbs Triumph 10
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
P TR3B Coil Issue? Triumph 7
P TR2/3/3A TR3B Panel Light Switch Triumph 20
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
J TR2/3/3A TR3b Tyres Triumph 6
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
W TR2/3/3A TR3B ‘TCF’ on BAT Triumph 10
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
tr3guy TR2/3/3A Late TR3A, TR3B windshield assemply Triumph 5
K TR2/3/3A Windshield stanchions on a TR3b - guide plates?? Triumph 13
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
M TR2/3/3A After Market Oil Filter - TR3B Triumph 8
M TR2/3/3A Technical Assistance Needed - TR3B Carb Adjustment Triumph 5
D TR2/3/3A Best TR3B seats - repair or replacement? Triumph 11
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
D TR2/3/3A TR3B Tire sizes? Triumph 10
S TR2/3/3A 155/15 Vredestein Sprint Classic on a 4.5" Wire Wheel as TR3B Spare? Triumph 6
J Restoring a '62 TR3B Restoration & Tools 2
M TR2/3/3A TR3B Door Cables Triumph 5
M Door Cables - 62 TR3B Spridgets 1
B TR2/3/3A Are these seat slides for a TR3B? how do you paint them? Triumph 8
B TR2/3/3A carpet snap questions tr3B Triumph 1
B TR2/3/3A TR3b lower door seal question Triumph 3
B TR2/3/3A tr3b center exhaust hanger Triumph 3
B TR2/3/3A steering box seal replacement TR3B Triumph 4
af3683 TR2/3/3A TR3B Exhaust Manifold Gaskets Triumph 15
C General TR TR3B Cylinder Head Triumph 7
af3683 TR2/3/3A TR3B Signal Flasher Problem? Triumph 2
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
B TR2/3/3A Identify the Mystery Bolts from TR3B front and interior Triumph 2
T TR2/3/3A TR3B fuel gauge Triumph 3
T TR2/3/3A TR3B stanchion to frame scew size Triumph 8
T TR2/3/3A TR3B alternator leak Triumph 4
T TR2/3/3A TR3B steering wheel cover Triumph 25
T TR2/3/3A TR3B VB windshield Triumph 11
M TR2/3/3A TR3B Front suspension Triumph 5
T TR2/3/3A TR3B gas cap Triumph 0
T TR2/3/3A TR3B steering column felt bushing Triumph 2
