TR4/4A Painting small bits on TR4A
PeterK
I started sorting out my project TR4A for painting and realized I don't know which of the small bits are painted body color, black, or left unpainted. So I need help.
Also, what about hardware for these items and for attaching fenders, etc. - bolt heads - painted or unpainted?
Here's my list so far of the 12 items that I need help with with my guesses: Please add any other items that I might have overlooked.
<span style="text-decoration: underline">TR4A Painting Bits</span>
choices:
Paint body color [body color]
Paint black [black]
Unpainted
1-Hood hinges [body]
2-Hood catch plate (on body) [body or zinc(later cars)]
3-Hood pin & catch (on hood) [body]
4-Hood prop rod [black]
5-Radiator support brackets [black]
5a-Grill support tubes [body]
6-Door hinges [body]
6a-Door latches & catches [plain]
6b-Door mechanism hex bolt heads [body]
6c-Door check straps [plain]
7-Windshield post brackets [plain]
8-Gearbox cover [plain fiberboard]
9-Driveshaft cover [body fiberboard]
10-Trunk lid support tube [body]
11-Trunk lid support slider [plain]
12-Trunk lock/latch [plain]
13-Bumper brackets f&r [black]
14-Rear fender outriggers [black]
15-Front fender bolt heads [???]
Like the TR3, parts were painted body color if they were assembled before painting. Variations in other bits are normal from car to car. It's a LBC
Geo Hahn
Your guesses are pretty good. I'm working from memory (not home today) and with a TR4, but here is what I recall:
1-Hood hinges [body] AGREE
2-Hood catch plate (on body) AGREE
3-Hood pin & catch (on hood) [body] AGREE
4-Hood prop rod [black] AGREE
5-Radiator support rods [body] -- Think these are black
6-Door hinges [body] AGREE
6a-Door latches AGREE
6b-Door mechanism hex bolt heads -- Plain (I think)
6c-Door check straps -- Straps are plain
7-Windshield post brackets AGREE
8-Gearbox cover [plain fiberboard?] AGREE, though oil-soaked is de rigeur
9-Driveshaft cover [body] AGREE
10-Trunk support tube [body] AGREE
11-Trunk lid support slider [plain] AGREE
12-Trunk lock/latch [plain] AGREE
TR4nut
Peter-
2) Hood catch on a TR4 is body color, and I'm pretty sure the catch on a TR250-6 is plain - suspect the 4A is plain as well since it is the same style, but that's a guess.
5) On the 4, the rod supports from the radiator to the crossmember are black.
Randy
Tinkerman TR2/3/3A Painting Small Bits on my TR3 Triumph 16
timsgolf Center Dash Switch Plate Painting Austin Healey 5
LAW75 Painting the Grille Surround Austin Healey 12
J Shroud Painting ["Finally done with these"] Austin Healey 3
GeorgeC Painting the Battery Austin Healey 0
J Painting Underside of Shrouds Austin Healey 13
J Painting a Frame and Substructure Austin Healey 12
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
S TR2/3/3A painting the floors of my tr3. Triumph 2
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J TR2/3/3A Painting floor pans Triumph 2
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
J TR2/3/3A Painting Triumph 11
S TR2/3/3A how to position pieces when painting Triumph 7
T TR4/4A Painting front hubs Triumph 2
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
69MGC T-Series MGTA Digital Painting 2 MG 0
B TR6 TR6 Painting/Restoration Triumph 2
69MGC MGC MGC Digital Painting MG 0
69MGC AH 3000 Digital Painting Austin Healey 0
69MGC Newest Digital Painting Aston Martin Other British Cars 0
B TR6 Painting a '74 TR6 Triumph 1
H Healey 100 Painting Austin Healey 5
KVH General Tech Questions About Painting Triumph 6
kennypinkerton General MG Rostyles. Painting question. MG 2
KVH General TR Painting the Engine Compartment with Spray Can Triumph 3
S TR2/3/3A painting the body tub “inside” Triumph 31
B Painting the Car - Corner Bead Advice Austin Healey 21
S TR2/3/3A I hate painting Triumph 8
J Final painting detail questions Austin Healey 16
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
Bob Claffie MGB Painting rubber bumpers MG 4
T TR6 Painting the car with the fenders on Triumph 7
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
madhouse Painting Wheel Wells of my 100-6 Austin Healey 8
drooartz General Tech Painting my Rostyle wheels MG 7
R TR4/4A Painting engine in the car Triumph 7
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Painting transmission Austin Healey 7
glemon New Painting Method Restoration & Tools 2
J Painting the car Austin Healey 8
Jim_Gruber Painting inside a BE Boot Spridgets 8
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
Brinkerhoff Painting or dyeing to change interior color? Restoration & Tools 2
D Live and learn… then learn some more… [painting] Spridgets 28
D Wheel painting frustration Spridgets 25
af3683 TR2/3/3A Painting Original Lucas TR3 Starter Triumph 3
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
wangdango inner body panel painting/welding/etc Austin Healey 3
