Overdrive Problems
bucaneer
Member
My overdrive stopped working. I changed the solenoid, did not help. The dash switch quit after installing the solenoid. What do I try next?
Keoke
Sounds like a switch failure. Try a new switch
B
bucaneer
Member
Thanks for the suggestion. I failed to mention that the car is a 67 3000.I removed the switch and the insulation was melted on the leads into the switch.Is this a switch problem or a sign of something else?
Patrick67BJ8
The OD circuit isn't fuse protected. I burnt my OD harness, plus part of the main harness several years ago. I never did find out what caused it because I swapped all the relays, tc.,parts from a parts car to it. I suspected the throttle switch or relay shorted out internally. You can try and disconnect the throttle switch and relay on the firewall and troubleshoot from there. I actually left my throttle switch disconnected for several years with no problems.
5
57_BN4
Test the solenoid coil resistance, it should change from about 0.4 ohm when the lever is down to ~11 ohm when the lever is manually pulled up to the engage position. If you don't see the resistance change as the lever is pulled up then either the lever is not adjusted correctly or the solenoid coil has burned out/shorted internally, or quite likely both if it has been driven any distance with the lever incorrectly adjusted.
There are many websites detailing how to adjust the solenoid lever correctly, it is a very common problem.
Andy.
TimK
My solenoid failed. I replaced it but used the original plunger. I put a 10 amp fuse in and blew it the first time i engaged the OD. The old plunger was not long enough to reach the button at the top of the solenoid cylinder to push the button that switches off the high amp pull-up circuit to the low amp hold circuit. I then installed the new plunger that came with the new solenoid and everything worked fine. It was longer than the old one. I think everyone should have the solenoid circuit fused. I did follow the adjustment procedures in the manual.
B
bucaneer
Member
I replaced all the overdrive electrial componets. the first time I cut on the switch I heard the solenoid click. when I attempted to start the engine for a test drive,while cranking the engine every thing elctrial died. The stater stopped and I have no wipers, turn signals,brake lights and fuel pump does not click. I have head lights, parking lights and horn. All was workig just before the attempt to start.Where do I start?
B
bucaneer
Member
All electrics are back on line and overdrive appears to be working. What range of rpms should the engine run in 4th in overdrive. Thanks to everyone for the help.
TimK
You can run to red line in OD. (5300 rpm)
B
bucaneer
Member
When the overdrive is engaged how many rpms shuld the engine drop. If I am running 4,00o rpms and engage the overdrive how many rpms should I now be running.
If you're running steady at 4,000 RPM and throw the switch the drop should be roughly equivalent to the O/D's rating (either 28% for early cars or 22%--880 RPM--for later 6-cyl cars). If you're accelerating you'll get a speed increase but little/momentary or no RPM drop.
TimK
I fused the solenoid circuit with an in-line fuse available at auto parts stores. You can select any amp fuse. I selected a 10 amp fuse based on advice from Keoke. It will blow if the pull circuit remains on for more than a few miliseconds. The hold circuit is less than 2 amps. All the other fusing shown in the photo I did later to put everything on fuses.
I got the fuse block from J.C. Whitney. Not elegant, but it works. Allows separate fusing for circuits that are controlled by ignition switch (like fuel pump) and those that are not, like lights.
richberman
buc,
Charlie Hart sells a fuse block which fits directly onto an unaltered Healey. If you PM me I can send you his email address. It's a $60 mod. Info is available at John Sim's Healey6.com technical pages.
rich
Patrick67BJ8
richberman said:
buc,
rich
These do not fit the BJ8's as the green wires are on the opposite side. I took Charlies fuseblock and made it work. I have to sort out all the pics I have but if someone needs to see pics they can send me a PM. I also have removed the OD system since I have a 5-speed, but there appears to be enough clearance for the OD stuff. I did have to move the oil line down & out a little bit to clear the main wiring harness but easily returned to original. Charlie is going to see about a fuseblock dedicated to BJ8's.
T Overdrive Problems Austin Healey 18
H Overdrive Problems Austin Healey 9
H Overdrive Problems Austin Healey 0
S Overdrive Problems Austin Healey 10
Torsten Overdrive install problems MG 4
7 overdrive problems MG 7
D BJ 8 Overdrive problems Austin Healey 16
H Overdrive problems Austin Healey 57
G J-type overdrive problems, again! Triumph 0
B Overdrive problems Again! Austin Healey 3
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
