OT - what do you think, put a Rover V8 in it?
tdskip
No engine or transmission...
GregW
I happen to have a 215 V8, it's the Olds version with Buick heads for higher compression. Would need a rebuild.
M_Pied_Lourd
Is that a Fiero Kit?
Cheers,
M. Pied Lourd
T
tdskip
Cheers,
M. Pied Lourd
In case you are serious, that is a real Ferrari 308. I can feel my wallet shriveling up just looking at it, and I'm not even seriously considering it.
jdubois
As a fellow who's own 308 is currently looking at $20K+ in engine repair I can say, couldn't be any worse than the original engine :eeek:
jdubois
Considering there are probably less than 2000 of Fiero kit cars out there, compared to over 12,000 actual 308's made, you're much more likely to see a real one than a Fiero look-a-like.
T
tdskip
Yikes. I bet that is how this one ended up w/out a drive train.
jdubois
Yeah, that's how a lot of them end their lives. The poor thing above is a nice early GTB. Shame to see it in that shape, but not uncommon. They've got finicky interference engines with tight tolerances. They don't take well to neglected maintainance, and the maintainance costs are expensive (belt/valve service every 3-5 years @ ~$4K or so, just to start). But once a problem occurs, engine repair can often times exceed the value of the car.
455 Olds w/transaxle from a Toronado....case closed! Toronado is Italian sounding at least... :smile:
HerronScott
Great idea! I've got a 1969 donor if anyone wants to take this on...
Scott
swift6
That's why they say that the purchase price is simply the entry fee to ownership.
pjsmetana
Didn't the 308 QV have a similar engine to one of the 80s model Fords? There was a Ford V8 with the same bolt pattern if I recall. I even just saw one for sale the other day with this 'swap' done. He wanted way too much money for it, naturally.
I can't even see 20K for a crate engine, let alone the cost of a used 308... Do love the look of those 308s though. A Red 1984 Ferrari 308 QV is on my dream car garage list... just below the Spitfire and a TR3, and just above the Red 1994 Acura NSX-T and the Yellow w/ Flames 1932 Ford Roadster T-Bucket.
Deleted member 8987
I suppose I can do an EFI mod on my 3/4 race 1950 Merc flathead to get the underhood clearances down......and a generator off to the side instead of on top....
Make a nice driver, Flathead Ferarri.....
jdubois
Hmm, don't know which Ford you're referring to. Unless it was also a mid-engined car, it'd seem surprising to me if the bolt pattern was the same, as both the tranny and the diff mount to the engine block in a funny way, and there's a three geared transfer case between the crank and the tranny input shaft that also mounts in there uniquely.
Me too... and I already had the TR3 and Spit :smile:
(BTW, why '84?)
Andrew Mace
Wait a minute, Pete! Which one do you want? A T-Bucket roadster (based on a Model T body up to 1927), or do you want a '32 -- often referred to as a Highboy in roadster/hot rod lingo? :laugh:
The only mid-engined transaxle "production" Fords that come to mind are the Pantera and the GT40 and it's related "kin".
cheseroo
I seem to recall years ago that someone made a kit to put a Ferrari V12 engine in the 308. There was a time that the V12's were somewhat available and not uber expensive. After all, they made the same engine for a number of years while people with more money than skill wrecked them. I always thought that would be a pretty neat car, the looks of a 308 with the sound of a V12. Hmmm, I wonder if a later 80's/early 90's BMW V12 would..........
Platinum
Now THAT would be a conversion I'd willingly live with!
As for the money/skill thing: I LOVE those guys. :devilgrin:
Last fall a pal an' I got the 3.6L engine from a well smashed Porsche Cabrio for a real bargain to slot into a track car he has. "Weekend Andrettis" have been a source for a LOT of good purchases.
swift6
That would be the Ferrari 365 GT4 BB and the BB 512/512i, though they used flat 12's. For a V12 to fit into a 308 it would have to go sideways or transplant a trnasaxle as well. The 288 GTO has a longitudal twin turbo V8 but the 308 is a sidewinder.
As an aside, there is a good chance that this particular 308 is one of the plastic cars. Did it specify in the description if it was fiberglass or steel bodied?
S TR6 If I put a rover V8 in TR6 what trans can I use? Triumph 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Got the engine put together Spridgets 4
S TR6 After I put in my new oil pump.... Triumph 3
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
M TR2/3/3A Where have you guys put your stereos and speakers? Triumph 3
M TR2/3/3A Phone charger & Radio can I put these in my car??? Triumph 7
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
glemon General TR Time to Put Your Tops Up? Triumph 12
jlaird Before I put in classifieds Spridgets 36
Bob McElwee Rode Hard and Put Away Lovingly Austin Healey 6
J How to put a stop on the end of a choke cable? Restoration & Tools 2
M Who put the stick in my heater hose? Spridgets 6
BN6_2197 What to put in steering idler reservoir of BN6 Austin Healey 2
drooartz Help me put together a plan for my Bugeye Spridgets 46
PAUL161 General MG Where Would You Put This? MG , VW, Motorcycle? MG 3
R 100-4 PUT-BACK-TOGETHER ?'s Austin Healey 2
RickB Just put headrest speakers in - wow! Spridgets 8
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
DrEntropy Can't put it off any longer. MG 10
M Body ready to be put on Chassis, 1 question first Triumph 9
B TR2/3/3A TR3. Would you put it back to right hand drive? Triumph 11
T Where to put the OD relay? Triumph 13
bugedd Before I put it on ebay.... Spridgets 0
K TR4/4A Can I put a TR3A Clutch in a 4A? Triumph 16
Basil Where to put that bumper sticker Spotted 1
middie Before I put engine back Spridgets 22
Jims71TR Put a new fuse box in now I have troubles Triumph 15
regularman Has anyone here put a bugeye front end on a square Spridgets 2
G GT6 Can I put a GT6 balancer [crank pulley] on a TR6? Triumph 2
BugeyeNJ58 Put on Harley Muffler--now backfires?? Spridgets 26
doughairfield Where to put the ground. Triumph 6
B Before I put the heater in my 57... Triumph 10
JPSmit Wasn't quite sure where to put this -youtube video Spotted 6
BugeyeNJ58 Radius arm came out...how to put new one in? Spridgets 6
bigjones Spare coil - put it under the hood? Spridgets 8
Marvin Gruber Put off too long Jaguar 4
T Did they put TR frames under these? Triumph 8
jackq Something to put in front of your MG MG 0
Tinkerman Need to put a new hole in my dash! Triumph 20
JohnnyMead What to Put Under Carpeting? Triumph 11
I TR6 TR6 put put sounds, part 2 Triumph 74
T What do you think - put a team together for this? Triumph 2
livinginthepast Stupid Q dejour - horn push/badge won't stay put! Spridgets 14
T Largest tire size I can put on my 89 xj40 Jaguar 1
