Oil pressure light
1976Midget
So what is the possible cause for the Oil light to be on. The car has oil and seem to run decent pressure on the gauge(if it right)
Bugeye58
Verify the oil pressure with an independent gauge that you know to be good. If the pressure is OK, check the sending unit, or replace with a known good one.
Jeff
Billm
If that light is similar to the one in the old 1098 Spridgets then it is a "caution" light that the oil filter is plugging and not filtering properly any more. It means that you need to change your filter. I don't know about the '70's era cars but this is a possibility.
Bill
1976Midget
1976Midget
that could be a good idea. i never have changed the oil in this car yet from it long time sitting. i plain to do so this week.
sparkydave
Don't '75 and '76 Midgets have the dual oil/temperature gauge? My '77 doesn't have an oil pressure light, but has the gauge. Seems to me the '78-'79 ones got rid of the dual gauge and went with the electric temperature gauge. If you're talking about the red light near the high beam indicator, that would be the generator warning light.
1976Midget
1976Midget
See i thought that was the GEN light. But in the Owners manuel it a Oil Pressure Light
sparkydave
That is interesting that the manual calls it an oil pressure light. I confirmed in the workshop manuals that it's still the generator warning light on a '75 and '76, so I suspect your oil pressure is fine and your generator is on the fritz.
1976Midget
1976Midget
yeah i found out i am an idiot and looked at the wrong picture. number 6 on one picture is the oil pressure Guage number 6 on the other picture is indeed the generator light. so i guess i do have good oil pressure but i dont have a good alternator.
jlaird
Hehe, things could be really bad and it be the other way around.
bugimike
Yeah, low alternator pressure!!! Yikes!! /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
1976Midget
1976Midget
so what kind of oil does an MG Alternator take anyways /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
1976Midget
1976Midget
You know after reading that website that a good idea. i know the new Lucas One i have on my 76 is very week. when you turn anything on it drops in voltage. so i may try this.
JPSmit
Not an oil issue - it's a smoke issue - definately replace the smoke canister and refill with OEM LUCAS smoke /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
jlaird
That's it of course.
bugimike
Morris said:
I just put a Delco alternator in my 1500. Aside from over charging, I am very happy with the conversion. It was cheap an easy. Check out this link if you are interested:
https://teglerizer.com/alternator/index.html
I made the conversion on my 1275 (in the BE) to a Nissan P/U alternator and have never had a regret! Prior to the switch, with the stock set-up I had regulator problems, tach drive failures and of course the voltage drop at idle. All things of the past!! /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
S TR6 Oil Pressure Light Triumph 2
T TR6 Low Oil Pressure Light Triumph 3
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
Gerry M TR6 Brake warning light & oil pressure light stay on Triumph 2
sundown TR6 1973 tr6 oil pressure light Triumph 3
hondo402000 TR6 71 TR6 Brake warning light and oil pressure light Triumph 6
VelodromeRacer Low Oil pressure light installation Racing 10
T Green warning light on but good oil pressure Triumph 1
F TR6 Oil Pressure Warning Light...TR6 Triumph 6
kodanja Oil Pressure light? Triumph 17
zimmy progress.....red light OUT...next....oil pressure? Spridgets 9
D Low Oil Pressure Indicator Light Triumph 2
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
S An oil volume question and an oil pressure question Austin Healey 5
