Most likely the ball switch on the side of the gear lever is not staying closed when in 3rd or 4th. Just put a little pressure to the right on the lever which puts more pressure on the switch. If it stays in with your hand on the shift lever, that's the problem. Removing a fiber washer from the base of the switch can sometimes add some pressure, or you may need a new switch. Tunnel must come off, Good luck, Bob
